ideas on mounting a flag?
Started by Skinny_Pedal, August 16, 2004, 10:20:45 PM
Skinny_Pedal
im gonna be going to some sand dunes in a couple of weeks and need a way to mount the flag. anyone got any pics of what they have done?
Im an OG
iNfErNaL
They sell antena mounting brackets that bolt on.You can pick them up at a dirtbike shop,or at a truck stop.I don't know what dunes you're going to,but I know that at glamis,they also have them at the beach store.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
Skinny_Pedal
im a washington boy so ill be going to moses lake
Im an OG
Skinny_Pedal
searching the web and i can't find anything?
Im an OG
Just tie it to your radio antenae
Skinny_Pedal
Im an OG
go buy a new one and git 'r done!  Bwahahahahahahaha!!!!
Skinny_Pedal
its a power antenna. i would like on the flexes. its getting really old really fast. for the flag i was thinking something i could bolt to the bumper and have a disconnect for the flag
Im an OG
Ive seen a lot of different mounts tha tpeople have made that were nice enough to leave on full time.  You could do anything from a peice of 1/2" pipe welded to a chunk of flat bar.  lay the pipe on the flat bar and weld it together, then drill a hole through the pipe and weld a nut to the outside.  Then all you'd have to do is mount the metal plate to a bumper etc. and stick the mast of the flag in the pipe and put a bolt in the welded nut to secure the flag.  Easy and basically free.
lowgeared
Hey, why not ask the Moses Lake guy!!  Heres the quickest way to do it for easy removal.  Use an air hose quick disconnect, I have two friends that do this.  Bolt it through your cage, bumper, or whatever.  Put the male end on the end of a whip antenna and there you go.  I usually just zip tie a shop rag or orange flag to the whip.  Easy removal when your done in the dunes and you wont tear your flag off when you get back into the trees.  Even a cheap ass magnetic mount antenna base with a long enough whip would work.  I don't do either of these.  I am always tying my antenna down when I go into the woods so it doesn't get torn off.  One of these days though.....
SWAMPER
ah my antenna was broken off by a branch...no biggie still get good reception and I figured that its not worth buying a new antenna since Im getting a CD player
Skinny_Pedal
lowgeared can u post a pic please?
Im an OG
Brandon
I like the air quick release idea - that's pretty slick..
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
lowgeared
Here's a pic of a quick disco setup.  Obviously, this wouldn't work as a CB antenna, just for a whip for the dunes.  Trust me-it's cheaper to have a flag than not have one at all.  Weld the larger hex part to whatever, and weld the smaller female end to a whip.  Pretty easy.  Oh yeah, it's easier to weld to steel rather than brass.  Make sure you get a steel whip, steel disco, and a steel coupler.  I've seen, brass and aluminum fittings, so check with a magnet if you're not sure.
lowgeared
Did I say disco? Anyone wanna dance?   :shocking: :afro: :afro2: :bayer: :bling:
lowgeared
Here's some regs on areas around me.  Including flag heights.
http://www.waatva.org/trails_cw.htm
Skinny_Pedal
i bought a orange one. should be fine right?
Im an OG
lowgeared
Red or orange is fine.  I've seen people fly big ass Confederate flags, big Chevy or Ford flags, American flags, and one of my friends even has a big yellow don't tread on me flag.  I guess as long as you're seen, you're safe from tickets and injury.  Now here's the weird part-the smallest vehicles, 2 stroke dirt bike with no lights, aren't required to have flags.  I wouldn't want one either for balance, but some of these idiots actually drink enough to ride them in the dark.  :smack:  I've had rock lights on with a strobe and head lights on at night.  It gets nuts sometimes out there.  People get killed out there almost every year.  Usually in a tent at the bottom of a dune and get crushed by a big Chev in the dark.  Just be smart.
brainlessfool
gesssssh, just JB weld it to the top of the cab  :twocents:
Skinny_Pedal
i already bought the stuff today for the disconnect. ill weld it inna few days and tell ya what i think
Im an OG
