The red rocket *Four link done..... Going turbo
Started by joey0712, October 05, 2008, 10:02:49 PM
joey0712
91 Toyota High pinions f&r.
GrenadedToy
Quote from: joey0712 on August 30, 2010, 08:52:02 PM
I got a flange from a guy on the turbo truck fourm. I was just gonna use u bends. Weld ells seem super heavy. I dont see why you would want them that thick?? Lc eng. header is made outta normal header tubing i think. Maybe cuz theirs is stainless?
you want the tubing to be at least sch 40 since the manifold will be seeing WAY higher EGT's than a N/A motor, most likely if you use anything thinner, like stainless, it will work for a little while, but crack over time from heat and stress. make sure you fab up some sort of support from the collector to the block/frame whatev.
ive heard of the lc headers cracking...
and their motors are retarded, $4k for 130hp? totally...
:twocents:
NITE KRAWLERS
Quote from: joey0712 on August 30, 2010, 08:52:37 PM
Im not that rich.
HA HA i wish i was too!! Those motors would be so sick to have man!!
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
joey0712
U can build one just the same for about half as much
NITE KRAWLERS
Hook me up wit the info man, I need to do something in my runner when i get it done. I can run the motor out of my truck is the plan for now. Its just the 22re, but i would like to just do a motor in the runner right from the start ya know!!
joey0712
Just run a cam header and free flowing exhaust... anything other then that is gonna cost some coin. I just think if you want power go turbo or do a motor swap.
NITE KRAWLERS
Which turbo's are the easiest to find to swap in? Celica's probly or not, i just don't know which toyota's really had a turbo on them at stock! I should know but its been awhile since i've dug into it cause i was going to do the 4.3 swap out of a s 10 i think is wat it was!! i've just been rocking the 22re for so long wit dual cases and 5.29's and gonna get 4.7's in the case i just dont need more power on the trail really. Its not my daily driver by any means!!
pumkin toy
Quote from: NITE KRAWLERS on September 08, 2010, 10:48:29 PM
none of the celica's had a turbo from the factory from what i know.  I could be wrong though!  your best bet is an engine swap of somekind or just a basic rebuild with a header, cam, bigger exhaust and an intake.  just those basics will get ya decent power.  I will help ya build a 22re mang!  i have built like three or four of em.  We did a full rebuild on my buddy Brandon's rig and that thing ripped!  Did a 30 thousandths bore, decked the head, bigger valves, header, exhaust, and he had an intake system built for it.  It ran really strong.  Anyways, enough with the threadjack! sorry joey0712
97 4runner Limited
NITE KRAWLERS
I'm down yo!! But we'll jump to your thread so we aint jack n man!! HA HA
toyotamobing
1996 Tacoma 3rz auto 4x4
1993 Jeep XJ 2 door 5spd 4cyl 4x4
1996 Dodge 3500 12V 5spd 4x4
@alteredegospeedshop
MAKING A SLOW TRUCK GO FAST SINCE 2003
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
www.polyperformance.com
joey0712
P-DiseToy24
joey0712
Im just messin with him.... I have plans...............
joey0712
Well i have been working on linking the front. I found out today that my Diamond has shipped . I will mock up links as soon as i have it. Ive cut the frame off just after the body mount. I used 2 in Dom to build the frame. I also lowered the motor 2.5 inches and made solid motor mounts. Ill post pics once i have my housing.
TacoRunner
Well, I guess my link kit wont work on your truck anymore will it.   Doh! :smack:
www.4WHEELUNDERGROUND.com
[email protected]
joey0712
I'm gonna run the same brackets as I have on the rear. Thanks tho
twistedtoy92
joey0712
Diamond showed up today! Now i got some work to do.
TacoRunner
[email protected]
joey0712
Aaronn
so has your mom come out and finished this thing for you yet ? I know your not working on it ...
joey0712
Ahhh i know im failing bad! Im gonna work on it today after work. Come help me.
yota4x4sc
sweet build...savage rear tube work..super percision welds and notches dude :turtle: :turtle: :turtle: :turtle: :turtle: :biggthumpup:
:usa: 92 xcab, full width, 39.5 boggers, beadlocks, 60 f arb 5.86s , 60 r spool , duals, 4.7 rear... 3.sl0, bobed , all pro 6 inch leafs f and r :usa:
joey0712
I got sooooooo much done.... ugh thats a lie.... tomorrow for sure!
joey0712
joey0712
I got the crossmember tacked up and the axle is at full bump. Im gonna order come new clamps for my ram so i can mount it on the new housing.
