The red rocket *Four link done..... Going turbo
Started by joey0712, October 05, 2008, 10:02:49 PM
Jud
Yea you cant get a better tire for yota axles imo...
"bout tree fiddy"
joey0712
Im so happpy with the way they work. I ran them for the first time at the Jambo. They hook up really well they are super soft. You run them also right?
91 Toyota High pinions f&r.
89sastoyo
one thing I noticed about my iroks and my tsls were my tsls got mad side buldge once they broke in, my iroks on the other hand with 30psi or 0 they looked the same and didn't wheel all that different. if I dropped 1 pound in my tsls from 13 and under it was like night and day as you went down in pressure. with 6 in the front and 4 in the rear they honestly wouldnt spin unless I was in mud.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
89sastoyo
I just realized that buggy was running mud grapplers how do they do? I never really seem them on anything other than tow rigs and mall crawlers.
92 2wd DD
first gen cab
joey0712
Ya i run mine around 5. Um they worked Ok.... He was running alot of air in them for some reason. I wouldnt wanna run them.
Jud
Quote from: joey0712 on May 03, 2010, 09:39:31 PM
Yea I just got the 39.5's but I use to run 36" iroks and those worked awsome especially in the snow.
"bout tree fiddy"
joey0712
Ya i would love to run in the snow. I cant wait to go to the beach with them.
89sastoyo
everyonne says they suck in the sand but I don't see how they could cause there by far teh best snow tires out. when I had my old 37s I could plow snow with the tires under the snow.
92 2wd DD
first gen cab
P-DiseToy24
Was out in the sand with a group of guys down here in socal and one of the dudes had a set of 39.5 iroks..... HAHAHA what a joke it was to watch him in the sand.
Dont get me wrong they dont work horrible and are great in any other terrain but as of a sand tire iroks blow....
joey0712
Ha thats good to know ha thats funny. A buddy has a set of paddles i could throw on.!!!
skyscraper
Quote from: 89sastoyo on May 03, 2010, 09:54:11 PM
I spotted that guy through a couple spots at the jambo, and from what I could tell they were horrible.  Luckily that buggy is like top of the line, so the lack of tires didnt slow it down too much
89sastoyo
thats wierd that he's running them with that nice of a buggy.
92 2wd DD
first gen cab
joey0712
I finally got my full hydro setup. I went with the 2 inch PSC full kit. Its pretty much done i just gotta get fluid and somehow hook up my steering shaft. Im gonna try and make my stock steering ujoint hook up to the orbital. If not ill grab double u joint from the hot rod shop. Here are some pics........ The kit went on pretty easy. It will be nice to be able to steer now.
joey0712
More...
Jud
flopp yea! I sooo wish I went with PSC instead of my TG. My TG works really good but PSC is just that much more bling...
"bout tree fiddy"
joey0712
Ya im pumped. Should have it going today. Gotta work on the steering shaft after work.
TacoRunner
www.4WHEELUNDERGROUND.com
[email protected]
joey0712
Yeah its getting bad. Ill pry run some tube from the front bumper to the a pillers soon.
joey0712
I havent updated this in a while so here ya go. I put a suck down winch on the rear. It really helps with steep downhills.
pumkin toy
nice winch setup dude, looks good.  How far along are you with that turbo engine rebuild?
97 4runner Limited
joey0712
Turbo motor is going good block is done i have a full rebuild kit from enginbuilder. Workin on finding the right turbo and im also gotta make some sorta turbo header..... The block has all ARP head and main studs now bored .20 over and the crank is polished. I still need to find a head im pry just gonna buy an enginbuildr rv head.
pumkin toy
Quote from: joey0712 on August 20, 2010, 08:50:27 AM
sounds like the engine should be pretty stout.  What size turbo you thinking of going with?  you want to use something other than the stock one it sounds like.
97 4runner Limited
joey0712
Ya my stock turbo is hammered. Im ether gonna run a ct 26 off a supra or a Garrett t3 t4
pumkin toy
does the ct26 bolt right up to the stock 4cyl manifold?
97 4runner Limited
joey0712
No it doesnt. Im going to make a header to fit whatever turbo i run.
GrenadedToy
Im pretty sure it does, there is just two versions with different exhaust housings, mr2 and supra. the supra will bolt up to the stock mani, just need to enlarge the mounting holes or something like that.
dont know if you've read this yet.
http://www.22rte-trucks.com/simplemachinesforum/index.php?topic=23.0
joey0712
Ya thats that one... Im pretty sure im gonna go with the Garrett t3 t4 that cary from got propane sells. From wat i hear its pretty dialed in and its all new... Im goin to build a header for it so ill just use the t3 flange.
GrenadedToy
good call, they are a lot easier to find then ct26's too. everybody uses em. you gonna build a top mount style manifold out of weld el's? I bought a bunch to do it, they are pretty cheap but need a lc engineering header flange first.
have you seen the how to on the sds efi website?
http://www.sdsefi.com/techheader.htm
NITE KRAWLERS
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
joey0712
I got a flange from a guy on the turbo truck fourm. I was just gonna use u bends. Weld ells seem super heavy. I dont see why you would want them that thick?? Lc eng. header is made outta normal header tubing i think. Maybe cuz theirs is stainless?
