Author Topic: My Locking Hub fell off  (Read 2082 times)
JeepMan4wd
  • Member since Jul '08
« on: Sep 24, 2008, 12:25:53 PM »
I have an 85 toy with what looks to be a set of stock lock out hubs on it, the alxe is welded.  I was driving around on some grass still in 4wd and took a turn and the hub fell off.  It snaped all 6 of the stucs that hold it on.  My question is "is this common" and what would cause this to happen?  Do I need to replace the studs on the other side?  Are they prone to breaking?
RABIDYOTA
  • Turtle Points: -107
  • Male Posts: 336
  • Member since Mar '06
Re: My Locking Hub fell off
« Reply #1 on: Sep 24, 2008, 12:49:51 PM »
???? is all of the shaft there,  my bet the bolts were not tight
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
« Reply #2 on: Sep 24, 2008, 02:36:04 PM »
X2, they usually don't shear unless driven really hard or loose
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
« Reply #3 on: Sep 24, 2008, 02:41:59 PM »
The nuts where not tight. Replace them with some FROR studs and forget about them forever. :thumbs:
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #4 on: Sep 24, 2008, 02:53:32 PM »
ive seen that only happen on rigs that had loose nuts (either holding on the hub or behind the wheel ;) )
RABIDYOTA
  • Male Posts: 336
« Reply #5 on: Sep 24, 2008, 03:12:14 PM »
 :funny: :driving: :woohoo:
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #6 on: Sep 24, 2008, 03:41:22 PM »
You not only sheared off the studs you also broke off the two hardened locateing pins. Good luck on getting them out. I would just buy a new hub, much easier.
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
« Reply #7 on: Sep 24, 2008, 05:21:03 PM »
I've only seen that happen on a truck hammering it with 39.5" Irok's.   I'd bet they were loose.  You can get ARP studs for it you need stronger than stock Toyota.
Quote
JeepMan4wd [OP]
« Reply #8 on: Sep 24, 2008, 05:46:33 PM »
What r "FROR" studs and where can I get them?
  • Male Posts: 8,707
JeepMan4wd [OP]
« Reply #10 on: Sep 24, 2008, 06:08:42 PM »
Thank you very much
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
« Reply #11 on: Sep 25, 2008, 09:49:30 AM »
Call Marlin, they can drill and install extra pins too!!
Either that, or call Bobby Long for some slugs!  Guaranteed to break more stuff!  :rofl2:
Pat
  • Turtle Points: 786
  • Male Posts: 944
  • Member since Jun '02
  • Oroville, Ca
« Reply #12 on: Sep 25, 2008, 09:57:39 AM »
wheres the end of the Birf?  :headscratch:
Sharing time between Northern Ca and Western Tn..
Last post Aug 12, 2006, 07:10:25 AM
by Rockdiver
Last post Jun 03, 2008, 06:10:20 PM
by WHITE_TRASH
Last post Aug 21, 2008, 11:54:40 AM
by halfxspaid
Last post Jan 02, 2009, 06:36:45 PM
by Plekto
Last post Feb 23, 2021, 02:48:03 PM
by LittleSteve
