speedo gear
Started by 4rox, August 14, 2004, 08:22:52 PM
4rox
I have a 94 ext cab w/350 and a ford 9inch.I keep shredding the speedo gear.The transfer case is out of a 4cyl.I tried a v6 speedo and it worked for about 3 months.Does the landcruiser have a beefier speedo gear and will it work?
I'd rather push a Toyota than drive a Jeep!!!
Marlin
The landcruiser uses the same style gear.
Check the metal drive gear, is it damaged from a loose steel ball in the rear housing?
The V6 chain driven case uses a much larger speedometer gear that will not work in a gear driven t-case.
How did you put a V6 chain driven gear in a 4 cyl gear driven case? It will not fit :_order:
Marlin
