turbo auto tranny
Started by Skinny_Pedal, August 13, 2004, 06:01:45 PM
Skinny_Pedal
hey guys. i may be coming up with a working auto turbo tranny. i curious to what this tranny will bolt up to? maybe ill find a truck with a blown tranny, put this in and make some money?
Im an OG
Prismo
It will bolt up to 22re for sure. A340H tranny I believe
Marlin
It will bolt up to any 86-95 22R, and by changing the bellhousing, 88-95 V6.
I was told by a Toyota tech that the turbo auto has a added cluteh pack, but my auto trans man told me that there is no room for the added disk.
I also believe that the rear output flange is the oversize 4 1/2" style with the 11 mm bolts mm like what is found on the manual 5 speed transmission t-case.
Marlin
Skinny_Pedal
so there will be a little work to make it fit but it will fit, good! could i take the rear output flange from the blown tranny and put it in the turbo? what exactly are the clutch packs?   thanks
Im an OG
Thats a long story about the clutch packs.  Ill give you the run down at tsf, w/pics if you REALLY wanna know.
Skinny_Pedal
we'll just discuss at TSF. give us something to do. ill proboly have it there
Im an OG
