As for the front, I would build new shakle hangers. Put the shackle hangers on the bottom of the frame (instead of through the frame) just a little bit foward to correct your shackle angle and then run a shorter shackle if you dont want the lift its gonna give you. And this will let you keep the front drop box right where it is. As for the rear, I would go get some 1/2ton chevy springs.Just my
When I did the lift I welded my spring hanger a little to far forwards giving me a bad shackle angle, almost straight up and down.
straight up and down shackle aint a problem itll just give you a stiffer ride on the road. it looka alright to me.. i wouldnt go true the trouble of cutting it off
Started by mhemingw7 Parts For Sale
Started by YOguyDa General 4WD Discussion
Started by Doc Holiday Engine
Started by tom p Project Research and Build-Ups
Started by KDXSR5 « 1 2 3 4 » Toyota Pickup/4Runner Tech 1979-95
