I would certainly double check the bleed job and make certain of the rear brake adjustment so the pedal won't have to travel as far and might make the difference with the booster.keep in mind too, when you bleed the brakes the pedal travels further than normal and may have possibly damaged the diaphragm in the booster. Slim chance but maybe possible. Does the booster hold vacuum? it should as long as the check valve is good. Also check the vac source for any possible issues.Hope you find the problem. MCR is real close. You're going, right?
Yeah I do know that the pedal goes further... Ive bled brakes many of times
Do you mean hold vacuum as in when i turn the truck off that 3 days later i can get in it and hit the brakes once and it will have some pedal? If so, yes.
I am goin to MCR regardless. Ive been drinving like this for 2 months. I just am sick of having to give myself a lot more distance in order to stop.
No I did not replace the rear shoes....
Now with my truck when I turn it off the brakes are noticeably worse then with it on.
Ok, cool. Just makin sure I was clear. Is this noticeable immedeiately after shutting off the engine? or do you mean after 2-3 pedal applications with the engine off? If it's immediate I would likely say the booster is leaking. If it's after 2-3 apps I would say that is pretty normal. Maybe see what happens if you hold the pedal down with the engine off and see if it bleeds off completely like that.
Happens right after i turn the engine off....and, when I am on the brakes still rolling and turn the engine off, the get worse also.Id say its bad. Dammit
When it works like it should, it should get about 2-3 normal feeling applications once the engine is shut off ( inherent safety feature in case the engine should die unexpectedly while moving with the help of the check valve which locks the vac in the booster for this reason). If it's bad immediately I would say booster is no good. Unless, the check valve has failed. But if the check valve had failed you most likley wouldn't hear the hissing noise you described.
Yeah thats what I thought. The only thing that was throwing me off was the fact that its noticeably different when the motor is off but that makes sense that the check valve would be bad since its bad right when the motor is turned off.
Started by brainlessfool Engine
Started by kvn85 Parts Wanted
Started by Sparkplug Parts Wanted
Started by DeMented Toys Parts Wanted
Started by kneedownnate Parts For Sale
