HELP needed!! ecu question
Started by 88runner, August 10, 2004, 07:35:08 AM
88runner
OK, I think my 3vze ecu is shut, I've found a complete 93 truck for 1000$canadian(I'll have a spare motor and spare parts :greengrin:)
now the question, mine is an auto trans. and the other is a manual trans., I've looked on car-part.com and I see no difference in the part# of m/t and a/t so will a m/t ecu work with a a/t? ??? :help:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
why not swap in the 5 speed too. :greengrin:
88runner
cause I like the auto, I had the 5 speed on my previous truck and I really like being able to focus on the driving insted of holding clutch brake and gs pedal all at the same time. :driving: plus the auto give me more crawl ratio, maybe it's not great on a 22re but with the 3vze(low end torque and hp) I don't realy see the major upgrade with the 5 speed.
anyway, you don't know if it's the same ecu,some 22re have the same a/t as mine(a340h) so if it work on a 22re why wouldn't it work on a 3vz.
a340h have a separate computer on top of the tranny tunnel so I don't know if the ecu as anything to do with it. :help:
88 4runner v6,
solid axle'd
88runner
well good news it was not the ecu, bad thing is I already bought the other truck, but what's good about it I now have a complete spare truck :biggthumpup:
the trouble was the distributor it was changed at the stealer for a new one but the truck wouldn't start after the replacement.
thought it was the ecu but during winter I had done some experimenting with a 4 cylinder ingnitor and messed with the plug and 2 wire were inverted :smack: :smack: :smack: :smack:
but I found that yes the computer from a M/T can work without mod on a A/T
now I'm gonna keep all electrical stuff, throttle body, doors(will make half doors :eyebrow:), rear axles and sell the what's remaining piece by piece so I'll probbly end up making some money with it. :thumbs:
88 4runner v6,
solid axle'd
sno runner
The computer for the manual, and automatic are different, so if you want to run the A/T you'll need the A/T computer.
Peace Aeehh:)
Remo
35's, 5.29's, rear soft locker, front true trak, 4" Pro Comp, 3" body lift.
88runner
#5
Quote from: 88runner on August 14, 2004, 05:00:24 PM
Isn't that clear enough for you :duh: I did swap them and it work for the 88 89 v6 auto or manual trans.
If you go on car-parts.com and search for 88 v6 engine computer you'll see that they all have the same part# a/t or m/t.
:moon: :laugh: :hahaha:
88 4runner v6,
solid axle'd
sno runner
My bad bud, I just saw the year of your truck. that might be the difference why your ECU's are interchangable. My computer on my 95 burned out, and I replced it with a used one. Unfortunatly the one the shop ordered was for an A/T, which the  mechanic said would not work with a manual. Glad to here your back up and running.
88runner
Don't worry I knew you didn't see something.
95 is totaly different cause it's the first year of the 3.4l 5vze.
don't trust anyone from the dealer they don't know sh#t.
i.e. the other day I was arguing with a girl in the part departement telling her that v6 started in 88 but she was totally positive that it started in 86.
next time I'll see her I'll bet 3000$ that she can't find a v6 before 88 in notrh america. :eyebrow:
88 4runner v6,
solid axle'd
