but if the shafts are sleeved and turned into basically one long bar with wheel flanges at both ends, then wouldn't the two bearings on the ends of the shaft be enough? or do i really need 4 bearings holding the one bar up?
keep the diff so then u have a spare third?
only weld the pipe to one axle, actually if its long enough to keep it from sliding over to one side then it doesnt need to be welded at all, just pull one shaft out, slide the pipe in over the side thats still in the housing then slide the shaft thats left into the end of the pipe sliding it down onto it and bolt it upthe bearings on the drum housing are pre lubed they DO NOT get or need oil from the differentialthen just build a plate to cover the hole
I would run a third in it if your going to be using the trailer for your bikes. I would rather spend $100 buck on another third to build than have a problem with a funky setup & have to possibly replace some part or a whole bike or two or three
i think it will make a bunch of noise if u only weld one side. Because the unwelded side will spin whenever u make a turn.
nope its not like a truck with a spool..... it weighs nothin
Might be cheaper to buy a regular trailer axle rather than hacking up a Toyota axle.I know Scotty at Addicted Off Road built his trailer using a rear housing but also welded splindles to it so he could have an extra set of hubs as well. http://www.tacomaterritory.com/forum/showthread.php?t=106946
Started by Duckman Parts For Sale
Started by craigellis77 Project Research and Build-Ups
Started by Thomas P Parts For Sale
Started by yotadork83 Project Research and Build-Ups
Started by cruiserfj45 Parts For Sale
