cruise control
Started by Skinny_Pedal, August 06, 2004, 04:59:23 PM
Skinny_Pedal
i may have posted this before i can't remeber but lets try again. my switch comes on, on the dash. but the cruise itself wont set. ive checked the fuses because thats about all i knew to do with it. any ideas or diagrams to help me out. my chiltons did nothing for me
Im an OG
robinhood4x4
A malfunctioning CC will give trouble codes.  The chiltons should help there.
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
Marlin
After spending hours checking for bad wires, servo ect., I gave up and sent the truck to the dealer  :mad:
As I remember, it ended up being a burned out brake light  :smack:
Skinny_Pedal
u of all people to it to the dealer, wow. well i know its not that because my all my lights work. i guess im gonna have to fugure this one out solo!
Im an OG
mudguts
My CC went out over a period of time on my DD. I was told it was a vacuum leak. :dunno:
:nerv:        :turtle: I love T.I.T.S. :turtle:
