Author Topic: Wire Q?'s for AFM and battery move  (Read 1634 times)
jrock
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« on: Aug 18, 2008, 04:13:58 PM »
I'm moving my battery for the airbox move, I want to know if home service wire if large enough? :help: The wire saids 600V AWG 2 Oil and Gasoline Resistant and has 19 strands. Some other wire I have saids "6 type THW or MTW 600V" and has 7 strands. Then I have a battery wire from a donor car that is Al, I trust this one the most because it's for a battery.
And what wire can I use to re-wiring the airbox?
« Last Edit: Aug 19, 2008, 08:13:40 PM by jkief86 »
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
Re: Wire Q?'s
« Reply #1 on: Aug 18, 2008, 04:33:42 PM »
2 gauge is sufficient.  It came stock with like 4ga.  Where are you going to? other side of the truck or in the bed?
:worthless:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Wire Q?'s
« Reply #2 on: Aug 18, 2008, 04:45:56 PM »
Sorry, no camera.
Battery is moving from the passenger side to the driver, onder the hood. I'm swapping the location of the airbox with the battery.
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
Re: Wire Q?'s
« Reply #3 on: Aug 18, 2008, 04:49:05 PM »
yeah 2gauge is plenty.  I assume you mean for the main battery cable, correct? you don't need anything that big for the fusebox feed...maybe 8ga to be safe.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Wire Q?'s
« Reply #4 on: Aug 18, 2008, 05:18:36 PM »
Yeah, main battery cable and grounds. I will need to run a fuse box feed, but that's easier.
So I hear trailer tow wire works as extension for the airbox. Is there a 7 wire? and is the gauge large enough?
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
Re: Wire Q?'s
« Reply #5 on: Aug 18, 2008, 05:45:24 PM »
I wouldn't do that.  the AFM leads are what, 18ga? 7-way trailer cable is 6-12/1-10 (that is 6-12ga and 1-10ga) overkill.  solder in new wire of the same size as OEM, and heat shrink the connections.
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: Wire Q?'s
« Reply #6 on: Aug 18, 2008, 05:52:18 PM »
Good question Duffil. 2 gauge is great for a lower resistance drop across a much longer distance, such as under the bed.
But keep in mind, you want to use a braid of wire with as many individual wires as possible to spread the current load which will result in less heat buildup and therefore less resistance.
If the 4 gauge wire you have has triple the number of individual wires than the 2 gauge wire you have, then I would use the 4 gauge wire.
But really, just moving to the other side of the engine compartment won't require too critical a discussion here.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Wire Q?'s
« Reply #7 on: Aug 18, 2008, 05:58:14 PM »
Cool, I'll do that.
Bigmike, thanks for the tip and sorry, I erased your post by accident. The old positive lead was around 3ft, the new will be 6ft. This only goes from the + to the starter so I don't know how hot it will get but I would definitely like to get energy to the starter with as little loss as possible.
« Last Edit: Aug 18, 2008, 06:04:49 PM by jkief86 »
  • 511:1 Club
Re: Wire Q?'s
« Reply #8 on: Aug 18, 2008, 06:07:22 PM »
Ha ha, I was wondering where it went :) No problem, I have mad powers on this forum :thumbs:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Wire Q?'s
« Reply #9 on: Aug 18, 2008, 06:11:17 PM »
haha, there it is.
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
Re: Wire Q?'s
« Reply #10 on: Aug 19, 2008, 08:12:51 PM »
Okay, 1/2 done, I got the AFM all wired and working. And 16 gauge was way overkill, the wires were 20 gauge. I added 7ft to the harness, yeah, more that I needed. I soldered and heat shrink tubed all the connections, then tape wrapped the whole thing.
Cheesemaker
  • Turtle Points: 1346
  • Male Posts: 4,525
Re: Wire Q?'s for AFM and battery move
« Reply #11 on: Aug 19, 2008, 09:00:54 PM »
This is where a spare harness helps out.  I had spliced two coil wire leads together to make them longer and to reroute along the firewall instead over the head and exhaust.  Cleaned things up.
 :worthless:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #12 on: Aug 20, 2008, 03:19:18 PM »
pics on the way.
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #13 on: Aug 20, 2008, 03:50:56 PM »
here are his pics:
jrock [OP]
  • Turtle Points: 77
  • Male Posts: 3,395
  • Oodelally
« Reply #14 on: Aug 20, 2008, 04:42:28 PM »
Thanks Jim.
Last post Sep 28, 2004, 08:35:10 PM
by SWAMPER
Last post Mar 21, 2005, 12:51:02 PM
by Haz-matt
Last post Apr 05, 2005, 09:53:09 AM
by synwars
Last post Aug 15, 2007, 10:01:47 PM
by kiyul4130
Last post Apr 08, 2008, 12:12:52 PM
by RN37DD
