84 tranny ???????
Started by offroadmission, August 05, 2004, 05:10:56 PM
offroadmission
what tranny and t-case do i have in my 84 toy xtra cab 4x4?
FOR WHOSOEVER SHALL CALL UPON THE NAME OF THE LORD SHALL BE SAVED. ROMANS 10:13
FOR GOD SO LOVED THE WORLD, THAT HE GAVE HIS ONLY BEGOTTEN SON, THAT WHOSOEVER BELIEVETH IN HIM SHOULD NOT PERISH, BUT HAVE EVERLASTING LIFE. JOHN 3:16
lowgeared
More than likely a G52 and a forward shift tcase.  Check the tag on your firewall under the hood.  It tells you right there.
Skinny_Pedal
well i have an 86 and its a w56, but i dont know what the numbers would be for the t-case. im guessing i have a forward shift because i saw fw11
Im an OG
toyotaboy
g52 with a forward shift case... Unless it has been replaced then it could be a whole aray of things..
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
Skinny_Pedal
no i saw the badging for the w56. i need to know what the numbers are for the t-case?
Im an OG
toyotaboy
Quote from: 86runner on August 06, 2004, 03:47:49 PM
i was replying to the original question on the post... if you have a w56 out of an 86 then you have a top shift t-case..
rest in peace Effay
Skinny_Pedal
o it is a top shift.....wheew. that makes me happy now. my bad about the last post :smack:
Im an OG
toyotaboy
as far as i knw a w56 always came with a top shift. they came out in 85 and were in vehicles with the 22re. the 22r's had the "g" series trannies. :beerchug:
rest in peace Effay
lowgeared
Quote from: lowgeared on August 05, 2004, 05:45:51 PM
In 84, there wasn't fuel injection.  Correct me if I'm wrong, but fuel injection and w56/top shift combo didn't come out until 85.  I would have to say I'm 99.9% sure it's a G52/forward shift carbed 22r unless somethings been swapped.
lowgeared
I have a top shift case in my 84!  (thats because i changed it  :biggthumpup:)
Marlin
#11
All 84 xtra cabs were carborated and had bucket seats.
The trans is a G52 and will have a forward shifting [bench seat type] t/case.
All 84-88 carb'ed trucks will ALWAYS have a bench seat and the matching G52 or G54 trans with a forward shifting t/case.
The exception is all 84  4 Runners, SR5 short, SR5 long beds, and all xtra cabs. These are the only carb'ed trucks that will have bucket seats and a forward shifting [bench seat style] t-case.
Marlin
toyotaboy
Quote from: Marlin on August 06, 2004, 10:18:15 PM
The exception is all 84  4 Runners, SR5 short, and SR5 long beds, and all xtra cabs. These are the only carb'ed trucks that will have bucket seats and a forward shifting [bench seat style] t-case.
Marlin
there ya go...im tellin you, is there anything you dont know about toyotas?
rest in peace Effay
Skinny_Pedal
hey but we have an advantage of only being 17. maybe our knowledge will surpass the master :bowdown:
Im an OG
toyotaboy
Quote from: 86runner on August 06, 2004, 11:28:15 PM
we can try:)
rest in peace Effay
lowgeared
What's the difference between the G52 and G54?
toyotaboy
Quote from: lowgeared on August 07, 2004, 06:44:45 AM
marlins gonna have to answer that one for ya.. i dont know about differences on the insides but im pretty sure the g54 came in later modeled trucks that had a 22r. All 22re 4x4 trucks came with a w56 or an auto.
rest in peace Effay
Marlin
#17
Even Toyota does not make a definite change between the G52 and G54. Here are the facts for review.
All 84 G52's use the same 80mm x 20mm wide front input bearing as the 83 L52.
I have also seen this bearing used up thur Aug of 85' ?
Around Aug of 84', the newer, 80mm x 23mm wide input bearing was also used. Because of the wider stronger input bearing, the helix angle was increased on the input gear teeth and the matching constant run [front] teeth of the countershaft. This greatly increased the strenght of the unit but also makes it more prone to failure if run out of proper mesh.
It appears that by Sept of 85', [IFS trucks], all G's got the better 32TM03UR bearing ?
The early trans had steel 1/2 and 3/4 forks, with nylon rubbing pads on the 1/2 fork only. This proved to be a very poor design and prone to wearing out. Aluminun alloy forks were introduced around Sept of 85' ? and have had a very good service record.
Howevery, I have seen the wider stronger input bearing and improved gear set with the cheap steel forks called a G54 on the name plate.
I feel the G52 trans would have the smaller B32-14UR input bearing with steel or alloy forks. And the G54 would have the 32TM03UR bearing, stronger gear set and steel or alloy forks. But this does not alway agree with the name plate on the truck or the Toyota parts dept.
So much for making sense.
This is my short answer--there are also other minor changes as well :sleeping:
Marlin
