clutch????????
Started by offroadmission, August 05, 2004, 07:00:45 AM
offroadmission
will a flywheel and clutch from a 93 v-6 bolt up to my 84 22r? i think that i have already asked this but not sure since my search turned up empty. all help is greatly appreciated.
FOR WHOSOEVER SHALL CALL UPON THE NAME OF THE LORD SHALL BE SAVED. ROMANS 10:13
FOR GOD SO LOVED THE WORLD, THAT HE GAVE HIS ONLY BEGOTTEN SON, THAT WHOSOEVER BELIEVETH IN HIM SHOULD NOT PERISH, BUT HAVE EVERLASTING LIFE. JOHN 3:16
Marlin
#1
Absolutely not  :(
The 22R uses 6 crankshaft to flywheel bolts, the V6 uses 8.
The 84 has a 8 7/8" disk, and the V6 has a 9 5/16" disk. The matching pressure plates have a different bolt pattern.
However, they both use the same pilot bearing and the same height release bearing :greengrin:
Marlin
