toyota tranny swap
Started by ffatoyota, August 04, 2004, 09:55:08 PM
ffatoyota
will a A340F tranny go on a 3vz-e motor in a 1990 pickup
Marlin
Yes as long as you have the matching 3.0 bellhousing.
Just a side note, the 4 cyl auto trans has a 2.3:1 torque converter whereas the 3.0 came with a 2.0:1 converter.
Marlin
