Ok now this is going to sound off base, but it happened to me. My brake light came on AND my charge light at the same time. Turns out the brushes in my altenator where worn down to nubs. So my question is, does the charge light work when you first turn on the key? Is your voltage meter reading about 14-15 volts when the engine is running? Like I said, this sounds way off base, but if your altenator is not charging well, then it WILL trigger the brake light to come on as well. I purchased just the brushes for less than 5 bucks and installed them in less than a half hour. Took care of both of my lights coming on.
i have an 84 and my BRAKE! light in the cluster is always on what should be done to cure that and just like the other guy, my charge light also comes on when i first turn the key so does that mean i need a new alternator??
Started by 4runnerfromhell Toyota Pickup/4Runner Tech 1979-95
Started by yota_krawler Engine
Started by Tofudude Parts Wanted
Started by megolfer Parts For Sale
Started by skot80toy Parts Wanted
