...why buy when you can build?
Do you have any pics of what you are talking about?
...... just make sure you have proper shackle angle, and take into account settling and weight on the springs.....
he wants to mount his frame tube behind the body mount instead of the regular location where it is at.....i dont see why you couldnt mount it there...... just make sure you have proper shackle angle, and take into account settling and weight on the springs.....
May run into a between the tie-rod and the drag-link problem. You could always tub the rear of the wheelwell for more tire clearence.
shouldnt be a big deal. ya theoretically if the spring is 3" longer then ya put the tube back 3". something you might want to think about is where the center pin is on the springs you have now and the ones on the 51s. your axle could still get moved back toward the firewall quite some bit. id mock it all up first as best you could before boring a hole through your frame.
Started by Thumper Engine
Started by jimbo74 Toyota Pickup/4Runner Tech 1979-95
Started by greg_k113 Engine
Started by NCK4L Engine
Started by Aaronm Parts For Sale
