22r to 22RE conversion
Started by DeMented Toys, August 03, 2004, 05:39:27 AM
DeMented Toys
     I am building an 83 toy.  I recently had to retire the stock 22r engine.  The replacement engine I picked up is a 22RE.  The truck is set up for a 22R.  The 22RE that I got is complete with intake, ect.  Anyone know where I can get an EFI kit to run the 22RE in the truck?  Or could I swap the intakes and run the original carburator?  The carb wasn't in the best shape to start with and needed rebuilt or replaced...  I was going to go with a Weber carb before I got the 22RE...
Jeff DeMent
-DeMented Toys-
kyle_22r
if you want to go back to a carb, just unbolt the intake from the head and bolt the carb intake up.
you'll probably have to do some work to rig up a wiring harness for the EFI to work.  i've decided that the route i'm going to take is to just run an aftermarket, fuel only EFI setup and step up from my 20R to a 22RE.  this would allow me to get rid of the problematic AFM and just use a map sensor :thumbs:
Mike D
yeah the 22r to22re conversion would not be cheap. cause you would have to buy the ecu a fuel pump do some wiring and hook up the efi relay but it is better than the carbs expescially if yours was not really any good. You also get a few extra ponies. :driving:
87 runner, 4" trailmaster lift, 33" TSL/SX, 5.29's V6 e-locker, 22re that cost too much
DeMented Toys
#3
     The EFI setup from LC Engineering will cost me at least a grand...  I am thinking of just swapping intakes and buying a new weber performance carb...  Anyone had experience with the weber toyota carbs?
Jeff DeMent
-DeMented Toys-
Mike D
weber or holly are great most of my friends run holly carbs but webers are just the same. :biggthumpup:
CrabDiggs
It's all about the EFI, it may be a pain in the butt to do the conversion, but when your gettin with it, the last thing you wanna hear is put, put, put.   :moon:
88' Runner on 40" MTRs. Exo'd, Dual Cases w/ 4.7, 22Re, Waggy Front w/ Fox Coilovers, V6 Rear Still Sprung.
kyle_22r
doesn't look hard to do, especially if you find an '83-84 celica with analog EFI.  much simpler than later versions.  individual components are expensive, but usually can be had cheaply in a package deal
i have a weber 32/36 on my 20R.  it actually has a smaller CFM rating than a 22R carb, but much higher than a 20R carb.  knowing this, i think it would be a better idea to use a weber 38 on a 22R application.  i don't have any complaints from my carb(other than it's a manual choke :ack: ), but it would be nicer if the rest of my engine was in good shape :hahaha:
DeMented Toys
After much deliberation, I think I am going to swap out the intake and go with a weber carb.  At this point it seems to be the simpler and less expensive option...
Jeff DeMent
-DeMented Toys-
WHITE_TRASH
Yup its a lot of work to do the conversion.  Wanna buy a weber? :eyebrows:
To The Floor
Go to ebay and buy the Weber 38mm outlaw carb.  There's a company called John's foreign engines that sells em on ebay.  Complete kit is $450
in the projects nooga, anything goes
DeMented Toys
I have decided to go with a 38mm Weber carb kit from Downey Off-Road.
Jeff DeMent
-DeMented Toys-
Makohon
ever consider going propane? im thinking about it... ur engine lasts longer, more power, and will always pass smog. check it out at gotpropane.com then you wont have to worry about all these dam electrical connections/computers.... engine wont bog out.... engine never has to adjust itself when going to a high altitude area etc....
91 std cab, flatbed, 35 mtr's, aussie, 5.29's, 4.7's, twin sticks
Mike D
 well what if there is no propane tank nerby... you get stranded.
Makohon
thats why you get two tanks and depends on what kind of driving your doing, usually ur not driving to long of distances if you have a crawler.. plus just about everyother gas station can fill tanks...  so its not that big of a problem... yes finding a station that fills propane tanks is 1 in every 2 or 1 in every 3 stations but i cant recal any trip that i have gone on were i havent seen a place i would be able to fill, i guess it depends on were you live but im in northern cali and it wouldnt be a problem at all.
Mike D
well now that i think of it there are a few around here.
fast68
Quote from: snakeeyes on August 03, 2004, 05:39:27 AM
im parting out my 88 pickup with 22RE in it, runs good 127k miles, brakes now blown, so its going bye bye, and cab is rusted beyond any repairs, also the auto trans runs good, it is A43D tranny
you need anything off this truck ?
thanks
crawlerdan
im sure that if you scan the bible that is marlin crawler, you will find a how to conversion page :yesnod:
Tice
I coverted my 85 to EFI. What a pain!!!!!!!!!!!! Well getting a harness was a pain. I got the whole set up including the tank for 200 bucks!! :yesnod:  But the guy I bought it from was putting it in a 83 so he cut all the wires for the lights, signals, heater,ect off. I found one on PBB from a guy in Canada for 45 shipped!!! I thought to good to be true.......it was!!!! One of the main plugs that had like 17 wires connected to it was fried!!!!!!!!! :mad:  So I ended up wiring in a new fuse block to the stripped harness to run lights and wipers and such.  Plus some of the wires running to the engine are not even hooked up.  They just had no where to go!!! :dunno:  But at any rate, it was worth the time and frustration. Idles up side down!!!!! till the pump has no fuel to deliver!! :greengrin:
www.wheelingarizona.com
crawlerdan
worth the wait and trouble!!! but if you ask someone whoes done it that will help!! :thumbs:
Tice
I also had two other EFI Yotas to look at when I couldn't figure something out. That helped too. :beer:  Even borrowed an ecu when I couldn't get it to run after it started (bad vacuum leak :hammerhead: )
CTENG in KS
Hmmm, I am not sure if i have an ecu, but i sure as hell have a complete, untouched efi wiring harness sitting in my shed... :king:
awhotrods
Go EFI, its the best mod I did on my 82.  More power, quick starts, smooth throttle response, and idles at any angle.  Check out off-road solutions, they make a conversion harness for the 22RE, thats what I used in mine.  Made it alot easier, but still a pain in the ass.
6.72:1
Quote from: snakeeyes on August 04, 2004, 05:47:18 AM
I have the Weber 38MM Double-barrel and it is fabulous!
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
