RK's beast.
Started by RK, August 07, 2008, 10:29:02 AM
RK
So Id thought Id start one, since Im gettin a bit more serious in my mods.
Got the rear regeared so far,
did the main work myself. but had to go to a buddy to get the backlash right. now it sits just bout perfect.
the front was a pita to get out. is still being regeared. My buddy is havving issues gettin the backlash right with the yukon master kit supplied shims. but, gettin close.
then i moved on to the doors, since i was waiting for the front diff.
installed the 4xinnovations quick release hinges.
next is gonna the the front bumper. as pictured above, can see whats left of the stock. Not much. thing is about to fall off. Im thinking of going with the 4xinnovations. I like the set-up minus the stinger.
But inbetween then and now, Im going to get some seats in there. Get rid of those stock ones. Gonna get these in there. Hopefully somewhat soon. http://www.mastercraftseats.com/sportsman.php
Then probably inbetween seats, gonna try and modify my ignition to push-button, relocate some switches also.
Max
Black Hole Racing - 84 Jackalope/79 Devil Bunny/87 Golf - Service rig: 2012 Ram 3500
Wermz84
1st one in.  :yupyup:
You got a locker in that diff?
I like to Drive!
RK
Rear diff is stock e-locker.
nothin up front yet. im tryin to see just how far i can push this ifs stuff.
Max
GJToyotabug
nice start it needs to be SASed though
Wermz84
Nice!  Ya man push it and have fun doing it.  :yesnod:
if you get the sportsman before I do let me know how you like it.  I'm contemplating a set with adjustable lumbar support.
I like to Drive!
MiniSimp
RK
Quote from: Wermz84 on August 07, 2008, 10:42:15 AM
not real sure as to when ill be gettin em. As Im not the one payin for em. But, will let ya know.
Max
what you got a sugar momma :dunno:
RK
Well. Seats went out the window. But, im fully regeared. 4wd works like a champ, and two new rear tires. So, next is two new front tires, and a front bumper. Which is needed very badly. Then Ill look at the tcase. See about regearing that or something.
Max
RK
well, here it is.
d44. gonna start rebuilding it, and gettin the necessary stuff together. the ifs has served me well and taken me thru a lot of crap. just damn tired of bent tie rods.
Max
JanMarie13
Ummmmmmmmm..........  so what beast is this going in??   Do we get a pic of a truck here or are you starting from the ground up?   :yupyup:
RIP Kyle, we love and miss you man.  :smooch:
Quote from: KYOTA on October 03, 2009, 10:33:31 AM
thanks for the smooch I miss you too !  :yesnod:
RK
im stickin it in the camry, you can see a rear wheel there. :yupyup:
Max
RK
So, decided to start the disassembly for the rebuild.
Max
GONZO97
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
Wermz84
I like to Drive!
JanMarie13
RK
also found the source of my creaking in the suspension. the drivers side alignment adjusters were rusted in place. had to bfh them outta there.
Max
Zs Confederate Toy
sub'd. I wanna see that D44 up under there!
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
RK
made some progress today.
Max
RK
more progress.....even tho my hands are still vibrating....
so, is it safe to weld fill these cuts that went too deep?
passenger front cab mount....
drivers
Max
Zs Confederate Toy
Wooo you are gettin there keep it up!
ZACH
87 Rock Rat X
Trail Junky
IronClad
weldem up and grindem down its no biggy
Annihilation  Fabrication
Do you need a Hammer?
locked 4x4
looks like fun,  subscribed.
RK
Now to get the rig higher before taking that rear crossmember off. using solid 2" thick pavers was brought up. might go that route.
Max
RK
on to the drivers side
Max
RK
final big piece gone. time to work on the sway bar mounts and grinding.
hmmm...how many diff places worth of dirt is there?
Max
RK
need a new sawzall too. killed it.
Max
RK
and i wondered why i had issues with the r/p
heres the axle.
Max
awhotrods
Keep up the good work!
