Nissan axel breather NEW pics
Started by Huhwhye, August 02, 2004, 11:19:57 PM
Huhwhye
PICS at bottom
There was a thread not too long ago that talked about axel breathers.  A link was given to a site where someone used Nissan breathers.  They also listed a Toyota PN.
I went to the Yota dealer, they wanted $7 :screwy:
Then went to the Nissan dealer, $3.50
Just thought I'd pass it on.
'04 Taco DC 4x4
mudguts
:nerv:        :turtle: I love T.I.T.S. :turtle:
robinhood4x4
You can also just rip off the cap of the stock breather and hose clamp a tube over it.  This is free.
Quote from: cruzilaWell, if the ideal of excluding the lesser equipped (stock or otherwise) is accepted... there is no fundamental difference between that and a Sierra CLub ideal of exclusion. If we cannot embrace the 4wheel users as a whole. We are not fighting for access. I cannot be that shortsighted
WHITE_TRASH
Quote from: robinhood4x4 on August 03, 2004, 10:07:08 AM
Yup 5/16th's fuel line is a perfect fit, its a bit too small so you have to force it on but once you have a #4 hoseclamp on it it wont come off!
Hyena
I used a peice of 3 inch hose clamped to the breather.  Then off the the hose comes an airline.  Everybody thinks i have front and rear air lockers hehehe.
Huhwhye
'04 Taco DC 4x4
Skinny_Pedal
bad ass. looks i need to get some 5/16 line of some sort. just bust off the top cap?
Im an OG
WHITE_TRASH
you dont have to "bust" anything.  just clean up the breather pretty good with a wire brush and youll see that the cap is pinched in 3 places, just pry the cap upwards using a screwdriver and your good.
Skinny_Pedal
ok just did my diff breather doing what wt said. there isnt mush room for your hose so u must use a hose clamp! o and u dont need more than 2 feet! i bought 4 feet  :smack:  so its wrapped around the shock bar a couple of times!  :biggthumpup:
Im an OG
84runner
I went to the hard ware store and got some brass a couple little zip ties and some line , I think it cost me about $8 and had extras
Skinny_Pedal
Im an OG
WHITE_TRASH
Ill have to do them on my 90 now but the 84 has been done with the vents going all the way up to the cowp panel with 5/16th's braided line.  :ack:
SWAMPER
The website where the diff breathers is at is www.toyotaoffroad.com just scroll down and youll see this auto scrolling menu and it will come up there...its and easy cool mod to do :thumbsup:
Huhwhye
'04 Taco DC 4x4
5spd
I did mine for free.......pulled some nipples off an old 22re intake (the small ones, 10mm) and put em in my diffs, a direct fit, used some hose I have laying around and BAM..done...............cost.........nuthin!
Huhwhye
'04 Taco DC 4x4
BLUCRUZ
#16
Quote from: 5spd on August 04, 2004, 06:05:20 PM
"Ditto" here, I used the small nipple one in the front diff and the larger one that went to the brake booster for the rear diff :eyebrow:
& a point for you Jim, cause everyone needs to have at least one turtle point!
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
SWAMPER
Hey this is a great replacement part, thanks for the post!
