new 85 toyota pickup
Started by punchyyoter85, July 28, 2008, 02:18:36 PM
punchyyoter85
i just got an 85 standred cab shortbox. i am starting to build it. i have in mind a 4 inch lift with some 4.88's and some sort of crawler gears? suggestions? and high steer i have a detroit true track that i am going to put in the rear. i also have a set of 33's that i pulled off my old 89. mabey next month ill get the dual stick conversion.
MiniSimp
Just place this order and you'll be good to go:
MC-12900, Drive Shaft 8' Long Spline Kit $179.00
MC-17102, Snap Ring Pliers $24.95
MC-17100, Snap-On 54mm Hub Socket $24.95
MC-14840, Brake Line kit (set of three) $79.00
MC-15010, Rock Plate Differential Armor $25.00
MC-14673, Spool Locker, 4cyl $189.00
MC-14693, Low Profile Magnetic Drain Plugs $4.00
MC-15201, Rock Slider Kit, 58 Inch, HREW $135.00
Hooded Sweatshirt $35.00
MC-12006, Knuckle Kit W/Wheel Bearings $145.00
Cage Kit, Pickup / 4Runner, includes shipping   $570.00
MC-14450, Transfer Case Assembly, Dual 2.28 & 4.70 4Cyl 21 Spline $1,375.00
MC-15300, Rear Bumper, 1979-1988 Pickup, HREW $299.00
MC-5351, Front Bumper, 1979-1983, Stinger, HREW $474.00
MC-12156, Rear Axle Rebuild Kit $165.00
MC-15100, Crossmember, 1979-1983, 4Cyl $195.00
MC-13551, Rebuilt IFS Steering Box   $299.00    $299.00
MC-17003, Axle Breather Kit, Pickup/4Runner    $29.00
MC-13114, Trail-Flex Lift Kit, w/4' Springs (includes shipping) $1,924.00
MC-14601, 4Cyl 5.29 R&P Gear Set   $195.00
MC-10077, Heavy Duty Shifter Seat, All Other Toyota Applications $10.00
knuckle ball kit   $29.00
Knuckle Pull Scale   $9.99
MC-14672a, Lock Right, 4Cyl $299.00
$7,219.89
That should give you a good start. :greengrin:
AaronB
MiniSimp
Quote from: Aaronb on July 28, 2008, 02:32:54 PM
only 7g's! no problem  :laugh:
But look at how nice it'll be with all those :bling:  :turtle: parts on it!
punchyyoter85
yeah i have about $1500 this month. all that would be sick tho. i have alot of parts that are used that im just going to stick in. i got an 88 4runner last night with a loked rearend, i think its a spool. im not new to the toyota crowd this is my fourth toyota ive had and im 18. my second with a solid axle. but i do work at a NAPA so i get a good discount on parts! ill get some pics up.
ROCKO
Quote from: MiniSimp on July 28, 2008, 02:31:15 PM
$7,219.89
thats how i felt when i built my truck and im still paying on the credit card :yupyup:
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
punchyyoter85
about how much is it from a driveline shop to get your drive lines extended? when you run dual transfercases?
MiniSimp
Quote from: suicidejunky86toy on July 29, 2008, 12:20:39 PM
Around $90
Slolyfe
Thanks for reminding me of how much Ive spent and thats just the begining
You'll never take me alive
yotakid707
$7,219.89
only if i had 7gs id have a pretty bling ass truck too maybe oneday down the road
good luck on the build suicidejunky should look pretty good when your done
-Matt-
Nothinggg against what minisimp said, but theres A Lott of stuff in that list thats unnecessary, let alone half the crap you can make for half the price. you could get by with spending half that and have just as legit of a rig if you know what your doing.
o anddd.. :worthless:
Doof
and to add to that. if you make some :pokinit: on your own, your fab skills go up and your exp. points grow with confidence seeing the sliders you build hold up time and time again after hard mash and smash and still strong and straight
again... gotta do it
:worthless:
h0nke
post pics of this 85!! thanks  :hammer:
1980 SR5 shortbed pickup (Project Rust Bucket)
