Dana 60 Front?
Started by snowplow, July 12, 2008, 02:36:07 PM
snowplow
Anybody dont a dana 60 front that was stock toyota width? Im wondering if it can be done. I think the d60's have the spring pads cast into the center. Im wondering if it would mess everything up. Just thinking for future....
Dustin
kiyul4130
the only way you can get that thing to fit under a toyota spring width would be to narrow the 60 and then move the spring pad in. other wise start making your hangar wider. like i am right now.
-kiyul-
ECV 7-11
KYOTA FOREVER
snowplow
you mean use the existing cast in one and put the other one wherever it needs to be, then shorten accordingly?
Redbeard1
Yes just use the cast one and cut down the long side tube as needed or call sky and get a full width hanger kit and dont cut at all.
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
snowplow
Cool, good to know it is an option. Thanks dudes
OOPS
Cheaper also, only one custom axle to have made.
