heater inlet/outlet
Started by toolman, July 06, 2008, 09:27:02 AM
toolman
Okay... so I pulled my old engine and installed my new lcengineering...Problem is I have the block off kit on the new one and didnt take my heater outlet off the old engine before i sold it, also its been a while so even if I did i have forgotten where the other hose hooks up :hammerhead:.....soooooo....I need some help please. I have the hose that attaches on the drivers side where the lower radiator hose attaches.. I need the location where the other one that comes off of the heater valve goes. ..Maybe someone can post a pic or something.
Thanks
'82 yota work in progress
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
toolman
Nobody knows where the other heater hose off of the valve attaches??? I know it goes around the intake somewhere but for the life of me I cant remember.. :smack:
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
TheCookieMonster
so mine goes off the heater valve to the heater core. then the other side of the heater core goes to the lower radiator hose. then on the passenger side i have a metal tube out the back of the timing cover (water pump area) that goes to the back of the block then runs up to the other side of the heater valve.and another one thats under the intake manifold loops up to the intake manifold. hopefully that helps and makes some sence  :beerchug:
toolman
ya that helps big time!!!! Thanks!!! I wonder if it really needs both of those.. I wonder if I could just take the one off the top of the manifold and hook it directly to the other side of the valve?? Or vice versa??? Now the prob is i have to get that tube from the back of the water pump!!! DAMN!!! Anybody have one laying around???
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
TheCookieMonster
im not sure..thats how mine has been hooked up since i got it. ive never had cooling issues. the more coolant you can hold the better your going to be with staying cool :cool: :beerchug:
toolman
Thanks for the info and pics..All I have to do now is get one or the other hose attachments.
33x12.50's
Fuel Injection
4" lift
flat bed
x-over steering
full float rear
L52HD
LC engineering pro
TheCookieMonster
no problem :thumbs:...glad i could help out
