What to use for a windshield?
Started by NorCalToy, July 05, 2008, 11:10:56 PM
NorCalToy
so im wondering what everybody uses for a windsheil in the vent of a rollever of your vehicle, i dont think a stock WS will ever fit again so any suggestions on waht i could use?
ill have pics up tomorrow of what im working with...
thanks.
EDIT:
:flamer: IFS
Hammerhead
When a friend rolled his '87 we just used a high-lift jack and some wooden blocks to push the roof up to a reasonable level where we could fine tune it with hammers.  The windshield guy was having so much fun watching us pound it out that he didn't seem to mind the extra time it took to fit it a few times to get it right.  That was 2 years ago and it is still in place much to my surprise.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
I have never seen a yota cab too mangled to get a windshield back into the frame....  I bought a rolled first get and with some high lift and sledge hammer antics got a windshield back into it and first gens have a gasket which makes it a real bugger compared to later era's...
KDXSR5
NCT, you can make a stock windshield fit again with a little work. Be patient and you will get it. Oh, and make your brother do most of the work since its his fault anyways.
RTA
4 Ton Heavy Duty Portable Hydraulic Equipment Kit
Must-have equipment for straightening, spreading and aligning auto bodies and frames
Ram capacity: 4 ton (2 ton with extensions)
Includes 3'', 6'', 8-1/2'', 16-1/2'', and 19-1/2'' extensions
Hydraulic spreader capacity: 1/2 ton
Hydraulic spreader maximum jaw opening: 3-3/4''
SS tubing for fast set-up
Shipping weight: 43 lbs.
Contents include: 4 ton hydraulic unit, 4 ton ram pump with 5'' stroke, Hydraulic spreader ram, 2-3/4'' flex head, Ram toe, Plunger toe, Serrated saddle, Wedge head, 90° V-base, Male connector, 6 ft. hose with half coupling, heavy duty case. Hose fitting: 1/4'' NPT both ends; Ram travel: 5";
ITEM 44899-1VGA
$79.99
So. Cal. ROCK BRAWLERS
KDXSR5
DTB
toy4x4ota
i bought one of these, but have yet to put it in. you can cut it with a jig saw to get it to work better for you windshield frame.
http://www.roadlessgear.com/Merchant2/merchant.mv?&store_code=toy&screen=PROD&product_code=RG130
i dont know if they have your exact model, but im pretty sure you can get them to cut out different size pieces.
LIFTED TRUCKS ARE GAY
Hammerhead
Oh dude, now that I see pics of it I say you can definitely fix it.  The one I mentioned above was way worse than that and we did it in a bit more than an hour.  It's easier than you think.  Go for it...  :yesnod:
Oh yeah, and if it was your brothers fault be sure to make him provide any sweat required.  :slap:
'88 X-cab, V6
Thats an EASY fix..   highlift and a hammer that'll take glass once again with no problems.  Remember your glass is glued in so any gaps just get more urethane. :gap:
Blake,  pull the headliner down,  take a hammer and a hilift  with some wood blocks so it doesnt distort  and  BOOM
pull the old windshield out  and make a  cardboard replica of it  to  check for fit  and  get that thing fixed
NorCalToy
yea, i think ill try pretty much that glen, first i gotta figure out how to remove that light thats right in the center there :smack:
:flamer: IFS
KDXSR5
NorCalToy
#13
windsheild straightened up:
EDIT: added in a before pic :thumbs:
EDIT 2: already linke din below :smack:
:flamer: IFS
that looks good, but  get inside  and  pound out those dents
Wermz84
Looking good.  How long did it take?  and did you just use some hammers?  :yupyup:
I like to Drive!
KDXSR5
he pushed it out sitting in the passenger seat with his feet
KDXSR5
Quote from: NorCalToy on July 07, 2008, 12:23:51 PM
both pics taken today, within about 5 minutes of each other :gap:
before:
After:
all i used were my legs, :dunno: laid on the passenger seat and pushed it up from that... :dunno:
Wermz84
I like to Drive!
NorCalToy
and easy, i gotta firgure out how to pull the headliner donw to fully get the roof finished up. :dunno: and it starts with that stupid little light thing (its actually really nice i just dont know how to take it off)
:flamer: IFS
see how easy that was,  now  work on dem dents :hammer:
Quote from: NorCalToy on July 07, 2008, 02:42:07 PM
take pics
NorCalToy
:flamer: IFS
Wermz84
Head liners are overrated.  :cheese:   :gap:
I like to Drive!
BLACKDOG
Quote from: NorCalToy on July 07, 2008, 02:54:59 PM
DONE!
pop those light covers off, the screw holes should be hidden under them
              -Ronald Reagan
NorCalToy
alright, i just called the local glass place and im gonna tow the manbeast (uh ladybeast, eh that sounds bad) up there probably tomorrow and check some fitment. for now though, i think im gonna go and make a cardboard template using the red trucks windshield. :eyebrow:
so later on ill update with how it works for me.
:flamer: IFS
