Torque Specs
Started by TigerToy, July 24, 2004, 10:31:38 PM
TigerToy
I need torque specs for the ring to carrier bolts, and for the carrier bearing cap bolts.  TY in advance.
BLUCRUZ
71 ft lbs on the ring gear & 58 ft lbs on the bearing cap bolts
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
84runner
Use locktite and it's would be a good investment in keepers for your ring gear bolts, ther usually on the front ring gear bolts but don'thurt to have them on the back
RAZOR
Just curious as to where you found that information. I am puting a lockright in mine and it doesn't say the torq in the Haynes manual. So i am just curious for future reference! Thanks
Finally Straight Axled, e-Locker, 5.29's, Lockright Rear, 13" travel tractor spline driveshaft, CV eliminator, Fully Gusseted front axle, Marlins almighty 5" Trail Flex lift Kit, 36" TSL's
In Marlin Crawler, I trust.
If you got the Nuts, Follow my Ruts!
Lift It, Fat Chicks Can't Jump!
Motocross, Because it Requires 2!
kyle_22r
every factory carrier i've seen has had the lock tabs on the ring gear bolts.  i'd trust a mechanical connection over loctite any day.
