dual case rules?
Started by toyotamobing, June 24, 2008, 03:10:01 PM
toyotamobing
Ive been thinking about getting dual cases and/or tcase gears, and I'm wondering what you can and cant do with them. some questions are can you only gear the rear case? for example if i had gears in my tcase and just wanted to add a 2nd crawl box? and do you have to have the lower gears in the rear? just all around general knowledge and "rules" of having and running duals.
1996 Tacoma 3rz auto 4x4
1993 Jeep XJ 2 door 5spd 4cyl 4x4
1996 Dodge 3500 12V 5spd 4x4
@alteredegospeedshop
MAKING A SLOW TRUCK GO FAST SINCE 2003
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
www.polyperformance.com
BLACKDOG
you can gear either the front, rear, both or leave them stock.
              -Ronald Reagan
Don't press the clutch in while engaged in double low while the truck is moving down hill purely by gravity. :nonono:
EarlKann
Quote from: BigMike on June 24, 2008, 04:48:00 PM
:rofl:  Unless you like replacing clutches!
Duffil
you can gear either case, but the accepted "norm" is to only gear the rear case, to minimize the amount of parts that see a torque increase...
Also, if you buy your gears and the doubler adapter at the same time, go with 23 spline stuff in the rear case...same price and a bit stronger.
toyotamobing
i have a forward shift tcase now so do i need a top shift for a second case or does it matter?
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
KDXSR5
From what I understand, you need the front crawl box to use the same shifter setup as your transmission/t-case setup originally used (foward shift or top shift depending upon transmission), and the rear case must be top shift.
toyotamobing
ok thats what i thought...
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
Volcom
Rule #1 - You will end up at the back of the pack on trail runs.  The Jeep guys hate how slow you can move on the trail  :rofl2: :yupyup: :ha_ha:
Rule #2 - Jeep guys will be envious of your super low gear ratio after watching you climb up huge rocks without slipping a tire  :greengrin:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
toyotamobing
i like those rules...
what are some more does and donts with dual cases?
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
Don't let Jeeps pass you on the trail, make them wait.
Taunt them by saying try and follow me.
porkchop
85 TRUCK AUSSIE IN FRONT LINCON AROUND BACK MARLIN 4" SPRINGS UP FRONT WITH 63 CHEVYS ON BACK. REBUILT 22R WITH CRAWL CAM AND FEW OTHER THINGS NOTHING HUGE JUST WAITING TO GET PROPANE ON IT. RUNNIN 35'S M/T WITH MY LONGFIELDS 30 SPLINE SUPER AXLES. 4.7's IN T-CASE AND ON THE WAY WITH DUAL CASES. FULL HYDRO WITH TG ROCK ASSULT PUMP AND 2 X 6 AG RAM
Rockcrawlintoy
dont do 2wd lo lo burn outs. ring gears wont last
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Yoat Goat
T urning
O ver after
Y ears
O f
T rail
A buse
toy4x4ota
im pretty sure you dont need a top shift for the rear, you can change out the shift rails and just remove the block off plate and the foward shift becomes a top shift. someone correct me if i am wrong
LIFTED TRUCKS ARE GAY
KDXSR5
Umm... that turns it in to a top shift, so yes you need a top shift for the rear. :thumbs: Either way it must be a top shift in the end.
toy4x4ota
Quote from: KDXSR5 on June 29, 2008, 01:25:07 PM
ya but i was saying you dont need to get a top shift for the rear, you can make it one
KDXSR5
FILDO
Just wondering, why does this ruin the clutch?
emsvitil
Quote from: FILDO on July 11, 2008, 03:45:30 PM
Clutches aren't designed to spin at 20,000 rpm............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Here's a scenario with purely made up figures....
If you are in 4th gear (1:1 out put) double low at 5k you are going 10 mph
So if you are headed down a hill in 4th and double low and its not fast enough and you hit the clutch with it still in gear figure the clutch disk will be spinning 10k rpm's at 20 mph... the disc will explode in the scenario...
KDXSR5
FILDO
Quote from: WHITE_TRASH on July 11, 2008, 03:59:32 PM
So when you need to stop while coasting down hill and in gear, what do you do?
Wermz84
Quote from: Volcom on June 27, 2008, 12:30:18 PM
:funny:
I like to Drive!
slabcs
Quote from: FILDO on July 11, 2008, 05:19:32 PM
Push that pedal in the middle?
Relentless
If I start a downhill and the rig starts to slide I grab another gear in a t-case....  If you do it quick it won't grind much. :greengrin:
