2.5 Ton Toyota
Started by Sluice Box Hero, June 11, 2008, 12:48:08 AM
nice!  looks like i a falling behind everyone.  Kyle will have his axles in before i even touch mine haha.  Good luck!
Quote from: rockcrawlintoy on June 12, 2008, 05:47:28 PM
ya
that was a wild ass guess haha.
sweeeeet
Quote from: ClownMan on June 12, 2008, 08:44:10 PM
looks like the D50 many have some competition now, lookin good man
ahhhh sheeeeit. i cant wait to see how he puts it all together.
Sluice Box Hero
well seeing as i was an integral part of the D50 build, im not too worried.  i learned what and what not to do with rockwells when building colbys.
well, tonight i didnt get any pics, but i also did get much done either.  borrowed the plasma cutter from work and cut the backing plates off the rear axle. ill get the 11" grinder tomorrow and clean it up all nice and clean.
ended up not shaving these housing.  after much deliberation and measuring it was determined that i would only be gaining 3/4" of clearance and it would have been a pregnant dog to get it all dialed in, so i skipped it out.  no big deal because ill be gaining 3" of clearance over the old 14 bolt anyway.
on the front housing i welded up some holes and get the spring perches all dialed in and ready to go, just need U bolts and plates.  also using a 6ft cheater bar i was able to break loose the TRE nuts and get the tierod off the knuckles so i can get the 40yo grease out of there.
i was going to reinstall the chunks, but im going to have to take them down to les schwab and have them use the semi truck impact gun to get the pinion nuts loose so i can get the pinion brake rotors on.  so tomorrow ill so that and get them back in the housing for final assembly.
the idea is to have the rear axle completely assembled and ready for pinion brake install.  the front will be a bit more involved with buying new boots, gaurds, histeer, pinion brake.
ill try and get some pics at the end of tomorrow night with the axles complete.  then ill be taking a brake until i get some parts.
Callen
"You know that feeling right after you take a huge dump? . . . . Awesome"
-Cartman
wow what a job you have in front of you... but damn your doing it quick.
thats guna be one sick ass toy
what rotors you using for brakes? and are you bring the WMS in at all or leaving it stock... and are the front and rear axles going to match in width and if not how are you going to compensate so it tracks right.
Sluice Box Hero
Quote from: Hyena on June 12, 2008, 08:50:49 PM
i wouldnt count on that. besides, yours will be way better/more bling. youve spent a lot more money/time. mine will be stock for quite some time i think.
edit: this is kyle. i thought i was signed in.
-Cartman
Sluice Box Hero
Quote from: that HO kid on June 13, 2008, 08:23:17 AM
not sure what you are meaning by WMS, but i think you are talking about the wheel base, and its at 120 right now and will stay the same.  as for that width they rockwells are 70" with the hubs flipped in, whereas a D60 id 69.5"  the current wheels have 3.75" backspacing and the new ones will have 4" so i will be exactly the same width and length.  basically im going for the exact same look with the rocks as i have with the D60/FF14.  the idea is for it to look totally sleeper.
off the les schwab to have the pinion nuts broke loose, then full assmebly by the end of the weekend.
Callen
Callen
-Cartman
NorCalToy
WMS= wheel mounting surface to wheel mounting surface, so axle width basically
:flamer: IFS
Quote from: NORCALToy on June 13, 2008, 11:13:22 PM
thank you bud.
Quote from: Sluice Box Hero on June 13, 2008, 04:17:17 PM
Callen
Callen
oh okay, well the reason i asked is cause the first pic you have up of the rocks in stands.... the rear looks A HELL of alot skinnier in width.
but explaining in words is harder for me to understand.... without photos to help explain. thats how i learn :thumbs:
im patient.
how did the pinion nut breaking go?
Sluice Box Hero
all broke loose and ready to go.  the rear is narrower than the front in stock form on rockwells, but when the hubs are flipped in it becomes the same width as the rear.
Callen
-Cartman
kiyul4130
he got them broke off yesterday.
-kiyul-
ECV 7-11
KYOTA FOREVER
Quote from: Sluice Box Hero on June 14, 2008, 09:56:54 AM
Callen
how cool. cant wait to see it all done
Sluice Box Hero
rear axle is all finished up.  fully sealed everything, the idea is to never have to take it apart again.
since a rockwell housing is square kyle had a good idea to just drill a hole in the housing for the leaf spring center pin and use the housing as a perch.  i thought this was a great idea and helps keep the rig as low as possible, so i drilled some holes and ground a nice smooth area for the spring to sit.  i will have some U bolts made when the time to slap these under get a little closer.
as for the front i will work on getting the chunk back in it tomorrow and finish cleaning it up.  since i dont have any axles for it right now ill probably just leave the hubs and bearing unpacked until the shafts get here.
after that its a waiting game as to when i will get the money from my 1 tons, could be next week, could be next month.  we will see.
ill get some pics of the progress later.
Callen
-Cartman
will the grease in the axles leak out those holes you drilled or no grease in the area?
Rockcrawlintoy
Quote from: that HO kid on June 14, 2008, 11:37:53 PM
grease doesnt leak. the oil might if he spends a lot of time on his roof
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
toyotanner
he could throw some rtv on the pin :yupyup:
Sluice Box Hero
i feel like :pokinit: and im never drinking again... .  ..totally got the shaft last night at the bear, threw me out because i was too drunk, bull crap.  anyway, im hung over as flopp and feel like :pokinit:, im not working on the front today.
Callen
-Cartman
Rockcrawlintoy
Quote from: Sluice Box Hero on June 15, 2008, 10:40:56 AM
Callen
until next weekend
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Thomas P
its way easy to get kicked outta the bear, my one buddy got kicked out 3 weekends in a row, the first time he was in the bathroom puking, i guess he deserved that one, but the next time they accused him of smoking dank in line and kicked him out before he got in, and the next time he had just got his first drink and was laughing his ass off and they tossed him for being too drunk... off one sip! haha, were you really too drunk? kinda sounds like it.......
'14 Camry SE
SCX10 Honcho on roids!
Sluice Box Hero
oh ya, i was really really wasted.  i deserved it haha.  dont remember much from last night for that matter.
still hurting and havent left the couch since my last post haha.
Callen
-Cartman
kiyul4130
wasted is an understatement. ask about rockcrawlingtoys reach arounds
-kiyul-
ECV 7-11
KYOTA FOREVER
Sluice Box Hero
i was drunk. .  .. it doesnt count. hahahahaha
still hung over, im going to bed.
Callen
-Cartman
Thomas P
'14 Camry SE
Quote from: kiyul4130 on June 15, 2008, 09:14:31 PM
:rofl: :yikes:  :phone:
Sluice Box Hero
enough already. . . .geeze. haha.  i dont remember, and it sounds like id rather not remember for that matter.
so,  today we have a little side project.  kyle picked up this 1990 dodge a fwe weeks ago for a good price.  well the injectors were getting rebuilt. so tonight we are going to get this thing put together and running.  well take some pics and run you all through our progress.
Callen
-Cartman
Doof
kiyul4130
no. well it could be but im selling it to make money to fund my toyota. its a nice truck to.
-kiyul-
ECV 7-11
KYOTA FOREVER
NorCalToy
what happended that your selling em now?
:flamer: IFS
Quote from: NORCALToy on June 22, 2008, 01:56:44 PM
do you even know what they are selling?
the DODGE not the rockwells.
NorCalToy
Quote from: that HO kid on June 22, 2008, 03:24:49 PM
AND the rockwells
http://board.marlincrawler.com/index.php?topic=47080.0
unless hes got 2 sets
:flamer: IFS
