Author Topic: Mystery noise diagnosis w/vid  (Read 4910 times)
UKMyers
  • Male Posts: 188
  • Member since Jan '07
« on: Jun 10, 2008, 01:09:19 PM »
I just got home from a 2 week 4 state wheeling trip. I ran my rig quite a bit to say the least. The last stop was at Browns Camp Oregon. When I hit the highway to head back to my buddys house where my trailer was I had a nasty mystery noise coming from my tranny/T-case area.
Here are the specs
1994 SASed Runner.. 3.slow stock V-6 tranny
Marlin Dual Ultimate Cases. I bought the cases ready to run straight from them in Jan 07. They have 8000 miles on them.
Here is the video of the noise
http://s192.photobucket.com/albums/z186/NKAWTG/?action=view&current=MVI_2463.flv
I have NO vibration and everything works fine. The sound completely quits when you let off the gas and gets worse if you get on it or lug the engine. It increases with RPM the faster you go. It sounds really bad. I drove it at 50 mph about 30 miles like that to get back to my trailer and nothing flew apart but I think it's probably about to.
Anybody have any ideas based off the vid?
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: Mystery noise diagnosis w/vid
« Reply #1 on: Jun 10, 2008, 01:11:42 PM »
Wow that is a horrible noise!!!!!!!!! :yikes:
No idea.
Dr.Maxwe001
  • Turtle Points: -23
  • Male Posts: 627
« Reply #2 on: Jun 10, 2008, 01:20:12 PM »
sounds like a machine gun going off
but I would start by looking at the drive shaft area and if that didnt show any signs of damage I would maybe look into the rear most output shaft of my t-case  and then go fwd from there  it sounds like it could be the rear gear has a few teath broke on it and when the teeth catch back up you can hearit hitting
IF YOUR LOOKING OUT THE FRONT OF YOUR 4X4 AND YOU CANT SEE THEN JUST TURN ON YOUR WIPERS. BUT THEN THINGS GET ALL MESSED UP LIKE IN LIFE.
WHEN YOU GET TO THE END OF YOUR ROPE JUST THINK THAT ALONG TIME AGO  YOU WERE THE FASTEST LITTLE SWIMMER TO THE EGG
08:55:22 PM BeccaLoo24 – i like to screw things
$99 scratch and dent drill press has drilled more holes than Ron Jeremy.
http://board.marlincrawler.com/index.php?topic=48342.0
[img]http://bo
ROCKO
  • Turtle Points: -49
  • Male Posts: 743
  • Member since Sep '07
  • NOR-CAL WHEELIN
« Reply #3 on: Jun 10, 2008, 01:33:07 PM »
 :yikes:
wow thats sound pretty bad might want to have somebody at marlin listen to the video
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #4 on: Jun 10, 2008, 02:18:40 PM »
X2 On letting Marlin folks hear it.
UKMyers [OP]
  • Male Posts: 188
« Reply #5 on: Jun 10, 2008, 03:47:03 PM »
I emailed them the video yesterday. I just wanted to get as much exposure as I could. I'm at a loss. It sounds terrible and obviously I can't run it that way but I can't fix it if I dont' know what is wrong and I don't want to pull the cases and tranny just to guess.
Plekto
  • Turtle Points: 27
  • Male Posts: 863
  • Member since Aug '07
« Reply #6 on: Jun 10, 2008, 04:28:09 PM »
My take on it is that something has completely bound up tight and there are parts in the xfer case most likely that are grinding against the stuck piece(a bad diff might also explain it).
Imagine the old bicycle card in the spokes trick - now with big metal gears.  Def wouldn't drive it another block without pulling it apart - lest it REALLY seizes up and takes out half of your driveline.(or you if at speed).
*edit* of course, ask MC - they likely know exactly what the sound is.
porkchop
  • Male Posts: 630
  • Yeah 2 @ 1 time
« Reply #7 on: Jun 11, 2008, 06:20:55 PM »
sounds like fat jap man beating up little jap man in your t\c  to me keep us posted that is for sure something crazy going on
85 TRUCK AUSSIE IN FRONT LINCON AROUND BACK MARLIN 4" SPRINGS UP FRONT WITH 63 CHEVYS ON BACK. REBUILT 22R WITH CRAWL CAM AND FEW OTHER THINGS NOTHING HUGE JUST WAITING TO GET PROPANE ON IT. RUNNIN 35'S M/T WITH MY LONGFIELDS 30 SPLINE SUPER AXLES. 4.7's IN T-CASE AND ON THE WAY WITH DUAL CASES. FULL HYDRO WITH TG ROCK ASSULT PUMP AND 2 X 6 AG RAM
spc mike
  • Male Posts: 428
  • Member since Apr '08
« Reply #8 on: Jun 11, 2008, 06:29:59 PM »
so you dont have the factory trasfer case any more??
84pickup
  • Male Posts: 335
  • Barnwell Mountain (stock) Texas TrailRiders Jam 08
« Reply #9 on: Jun 11, 2008, 06:56:08 PM »
could it be a rod knock? or some other engine noise?
lets not and say we did.
93tonkatoy
  • Male Posts: 463
  • Member since Jul '07
« Reply #10 on: Jun 11, 2008, 10:08:25 PM »
You didn't say what speed you were running or what gear you were in on the video.
Check your rear diff. I am calling loose carrier bearing cap bolts.
SAVE TELLICO post 491
Prismo
  • Turtle Points: 8484
  • Member since Oct '03
  • Living in the green house
« Reply #11 on: Jun 12, 2008, 02:03:27 AM »
Check to see if driveshaft u-joint/cv-joint is hitting horsecollar right behind the rear transfer case.
UKMyers [OP]
  • Male Posts: 188
« Reply #12 on: Jun 12, 2008, 09:05:07 AM »
Thanks for the replies... It's definitely not engine noise. It doesn't even start to make it till after 20 mph or so. I have a 23 spline Dual Ultimate in there behind my V-6.
Dr.Maxwe001
  • Male Posts: 627
« Reply #13 on: Jun 12, 2008, 09:18:40 AM »
I think it might be part of the gears in the rear most tcase  that might have broken off due to the amount of centrifical force from the v6  that has the gears over toqued and has them slinging around inside of the case as you drive
[img]http://bo
« Reply #14 on: Jun 12, 2008, 09:25:05 AM »
sounds like a cracked piston to me,  gets worse over 20 mph, ?? wrist pin slap
i could be wrong,  but thats what it sounds like
pull the drain on the transfer case, if chunks come out i was wrong
UKMyers [OP]
  • Male Posts: 188
« Reply #15 on: Jun 13, 2008, 12:21:34 PM »
If it was my engine it would do it sitting still when I revved the engine. It is most definitly in the drivetrain. I have the wife brining me home a stethoscope from work today so I can play Dr on it.
UKMyers [OP]
  • Male Posts: 188
« Reply #16 on: Jun 13, 2008, 03:54:04 PM »
Decided to pull the third.. lookie what I found!
93tonkatoy
  • Male Posts: 463
« Reply #17 on: Jun 13, 2008, 05:24:27 PM »
 :yikes:
Guess you did wheel that thing hard! Time for a new R&P set. What ratio was that?
Prismo
« Reply #18 on: Jun 13, 2008, 05:34:51 PM »
529's, locker & crush sleeve? Pinion will loosen=destroyed gears
UKMyers [OP]
  • Male Posts: 188
« Reply #19 on: Jun 13, 2008, 05:44:46 PM »
I have ran that third for almost 2 years and 10,000 miles with no problems. It's been through the Con end to end 3 times along with every other trail in Norcal. Third gear bombs trying to get up a rain slicked rock muddy ass hill will do it every time :)
MiniSimp
  • Male Posts: 5,120
« Reply #20 on: Jun 13, 2008, 05:59:33 PM »
Who did you get those gears from?
UKMyers [OP]
  • Male Posts: 188
« Reply #21 on: Jun 13, 2008, 07:55:54 PM »
I bought em from PORC off Pirate and had a reputable shop set them up. I'm letting the shop use their own brew this time.
MiniSimp
  • Male Posts: 5,120
« Reply #22 on: Jun 13, 2008, 10:29:15 PM »
See if you can hit them up on the warranty:
Package deal includes front and rear 79-85 Toyota 4cyl or 79-94 8" rear 4.11,4.56,4.88 or 5.29 Porc Off Road products ring & pinions with complete master install kits. THESE ARE NOT CHEAP CHINA MADE GEARS LIKE OTHER VENDOR'S OFFER. THESE ARE THE HIGHEST QUALITY GEARS OFFERED ON THE MARKET TODAY. WE ARE SO SURE OF THE QUALITY OF OUR GEARS WE BACK THEM UP WITH A LIFETIME WARRENTY AGAINST MANUFACTURED DEFECT'S. MASTER INSTALL KIT'S HAVE ALL KOYO BEARINGS & NATIONAL SEALS.
Dr.Maxwe001
  • Male Posts: 627
« Reply #23 on: Jun 14, 2008, 09:53:24 AM »
I knew I had herd that sound before when I wore my rear end out of my 93  I had a 4 cyl turning 35 and over time at highway speeds it gave way and makes a sound like a machine gun and I hate to quote myself but I knew it was the gears in the rear here is my quote from up top
[/b][/u]
[img]http://bo
Last post Dec 03, 2004, 02:57:59 PM
by Mike D
Last post Sep 10, 2006, 09:52:56 PM
by Duffil
Last post Nov 14, 2006, 05:24:23 PM
by flipskid
Last post Dec 17, 2007, 06:38:56 PM
by swervin curvin
Last post Dec 31, 2016, 05:43:39 AM
by jbramble24
