Cab Swap
Started by awhotrods, June 08, 2008, 06:47:27 PM
awhotrods
The cab on my 82 4WD is done & I found a clean 2WD cab for cheap.  Can anyone confirm if a 82 2WD cab will bolt on to a 82 4WD frame?  Thanks for any input!!!  :beerchug:
Angler
if it dont cut the cab mounts off the frame move them to where they need to be and weld them on. too easy
toyotanner
as far as i know they are the same.
i put a 3rd gen 2wd cab and bed on a 2nd gen 4wd frame everything bolted up.
awhotrods
cool, so it sounds like I should be good to go!
