Moving front axle 2" forward
Started by Suprarunner, July 18, 2004, 07:38:41 PM
Suprarunner
Just a tip, I have an 87 4runner with a solid axle swap running 36x12:50's. I ran into the problem of my tire compressing into my inner fender at full flex and jamming my steering up, so I was about to buy new springs anyways and decided to have the fronts punched two inchs forward to solve this problem.
Well stoopid me I did'nt take into account the possible repercusions of this and it ended up now I have $900.00 in custom springs from Alcan and when my truck flex's now my tie rod clips my drag link. And I just thought I couldnt steer before with a tire jammed in the fender!
Well, long story short if any of you guys are having this problem and want to move your axle forward and are running hi steer, my buddy with the same setup as me got away with 1.5" without no problem, if you wanna push it that extra .5 of an inch you might get into a major goat roping. Ended up I had to spend all day making brackets to move my steering gear box forward to compensate.
Ah yet another reason I have a scoutII box on my truck.
Suprarunner
Scout II?????? tell me more. Is this box stronger? What's involved with the adapting?
The only problem with yotota steering boxes is that the pitman arm swings to the rear.  A scoutII box swings to the front so you can mount the steering box in the same place that you would mount the toyota box, but you could put the front axle in front of the truck.  I have the axle on my 90 moved ahead about 3 inches now and the steering box is mounted next to the driverside motor mount.
Suprarunner
Good move, stronger steering or about the same?
Ferg
#5
If you use a power steering box from a late model Land Cruiser 60/62/80 series you can do the same thing.  The TLC box mounts using four (4) bolts instead of three.  Reference - Toyota Trails, July/August 2003 pp34-41.
see one here (not mine)  http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7911380517&category=33589
dirtyskivies
just move the ifs box further forward...
2002 trd v6 tacoma
1986 4runner type thing
1998 ktm supermoto
dirtyskivies
Quote from: WHITE_TRASH on July 19, 2004, 11:21:32 AM
seems if you had hysteer you drag link/tierod problems would be the same as his, possible worse
2002 trd v6 tacoma
1998 ktm supermoto
When I mounted the steering box the axle was moved forward 6".  I moved it back to comply with Calrocs regs.  The pitman arm that is on the box is a 2" drop also.  Somehow I had enough forthought to use it instead of the stock one I have.  I figure if I need the clearance I can notch the bottom of the frame for clearance. I would have moved the axle back but I dont have too much contact with the tires now but I will this winter when I put the 40" gumbo snow tires on so it'll go back forward.
84runner
WT what did you have to do if anything to adapt the power steering houses ? An is the turn ratio the same as the yota's or better ?
Yes the pressure hose has a uae fitting which is typical to saginaw boxes.  The box has about the same ratio as yota its 4 turns lock to lock.
mr4x42u
I agree with dirtyskivies,,,just cut the body out a little bit and move your box forward till it clears..It won't take much..I was surprised how little i jad to move the box to clear the steering..
