I'm not sure which it is... I only see one cable coming out from the firewall and I'm not sure whether it's the e-brake or the speedometer cable... Given that my speedometer now bounces...
My problem... Guy puts in exhaust. Looks lovely.
Forgets to tuck the cable back in behind the heat shield/tie it off. So it ends up touching the exhaust. And the foam/rubber insulation *catches fire*
![Yikes :yikes:](https://board.marlincrawler.com/Smileys/marlin/yikes.gif)
I got to it after a couple of minutes of driving(white smoke is pretty obvious ???what the hell???), but the cable - whichever one it is, is now missing a 2 inch section of insulation - just the wire casing is left...
So... Gotta take it back and get him to fix/replace it...
![Maddest :maddest:](https://board.marlincrawler.com/Smileys/marlin/maddest.gif)
Just wanted to vent I guess.... You think he would double check to see if anything was touching...
![Wall :wall:](https://board.marlincrawler.com/Smileys/marlin/wall.gif)
Q: how do I tell which cable is which? I'm hoping it really isn't the speedometer because that's a total PITA to take out and put back in.
