intake part identification
Started by hessiankid31, July 16, 2004, 02:38:21 PM
hessiankid31
Does anybody know the official name for these parts? The rubber y-hose comes off the factory sound deadening box(is that the right term also?)and goes to air box and resonator and the boxes are part of the resenator assembly on 3vze v6,. I'm writing an article and I can't find the correct terms
Its not "AT" anywhere! 91v6 Toy sawzall special w/ twin turbo thrack-u-lators, 01 Taco4cy cream puff,85 220whp 5mge Supra,multiple FF Honda civics
Marlin
Yes, these are the harmonic noise dampening componets that eliminate the high rpm air flow noise.
For the proper terms, I would go to the dealer, i d the parts on their computer, and get the proper info.
Marlin
84runner
Just call the dealers parts department and explain what the parts are and tell them you want to get a price on them, and ask what they are called  :biggthumpup:
