tire size
Started by yota18, May 27, 2008, 10:42:28 AM
yota18
i was wondering if a 33-12.5/15 would fit on my 84 pickup with a 1.5 inch shackle lift. i have 31-10.5/15 on there right now.
33's would be too big you will need about 4 inches to clear them and not rub.
yota18
Quote from: Rocksurfer on May 27, 2008, 11:04:07 AM
or a hammer and a saw
toyofan7987
i have a 83 with negitive arch front springs and 33 12.5s only rubbing was on the plastic inner fender .. a little dremel solved that problem
KDXSR5
hmm... I have 30s on the stock 85 with negative arched springs, and the tires are contacting the firewall bad enough to cut them up.
yota18
now if i was to put wheel spacers on would that help at all.
Rocksnail
My 82 had 33s on it when i got it. and they didnt rub. no lift all stock suspension. front leafs where neg about 2 inches as well :beer:
1993 4door  s10 Tahoe. 4.3 th350c duel toys w/4.7 rear, D60 front 5.13 welded. 14Bolt rear 5.13 mini spool,hydro assist, TG 5HD front springs, 63s out back. h2s with 39x14 17 Pit Bull Madd Dogs
MiniSimp
On my 88 I ran 33x12.50's with no rubbing.
Wheel width and backspacing has a lot to do with it.
yota18
what is a good size for the back spacing and how do you measure it
brandon95
U could run 32s, im runnin 32x12.50 15 on my 3rd gen with no lift it only rubs if im doin somthin stupid.
94MtnYote
 my buddy runs 33x12.50 on his 84 with a 2in shackle lift and negative arched in the front. they only rub if he's playing too rough.
Marlin 1200LB clutch
toyotamobing
i have 33x12.5s on my 84 with flat fronts and 2" longer shackles in the rear and it didnt rub till got my welded thrid or i hit a bump and full steering lock
1996 Tacoma 3rz auto 4x4
1993 Jeep XJ 2 door 5spd 4cyl 4x4
1996 Dodge 3500 12V 5spd 4x4
@alteredegospeedshop
MAKING A SLOW TRUCK GO FAST SINCE 2003
!!POLY GOATS!!
www.polygoats.com
POLY PERFORMANCE
www.polyperformance.com
yota18
cool i wasn't to sure about thanks for the help
