How much power will a toy tcase handle
Started by snowplow, May 24, 2008, 01:31:09 PM
snowplow
Just wondering how much power you guys have successfully ran through your toyota tcase? IF you got them to break what is the weak point?
Thanks Dustin
Bazzi
I want in on this... I have been told that the toy gear cases are amoungs the strongest t-cases out there...
snowplow
Me too, I have heard of a guy breaking an output shaft on a 700R4 chevy trans before the toy tcase broke. I bought all my stuff a while ago, then I got a little too carried away on the motor and im sooo scared Ill pop it open. Right now I can send it all back if I have to so I was looking for someone to make me feel better so I sleep good tonight!
Bazzi
what kinda trans, engine, and what kinda mods... give me the dirt. :wiggle:
snowplow
Bazzi - I am building a 418w (351w with a 4.100 stroke) should make 500ft lbs so I hope the old girl if feeling strong! Trans is NP435 with 6.69:1 granny gear- transfercase is a single toy gear driven unit with 23sp 4.7 total spline gears and I am thinking of buying the billet reduction box housing from A/A- Fancy SAS with e-locker High Pinion and 30sp longs- Spool rear - 4.88 & 37x14.5 TOYOs
Ran this truck with a 289 for years but now I want something BIG. When I bought all the stuff I didnt plan on making the motor so big so I was just wondering if my TCase is going to go BOOM  :yikes:
Birfailed
I saw a toy case split the output shaft.  Runnin the 4 banger and duals with 4.7's...stranded us overnight on helldorado between my truck and his.
Go 1-Ton from the start
crawlerdan
Quote from: snowplow on May 24, 2008, 01:31:09 PM
Thanks Dustin
in high scool a freind had a blown small block in his 79 4x4, stock 21 spline t case, he would routinely roast the piss out of all 4. the motor made about 450 horse and he was very unfreindly to that drive train-fast foreward 10 years-still has the same t case in it-no rebuilds at all
boggerunner
i broke an output shaft behind a 150hp 22re/w56/21sp/21sp 4.7"s with 37 mtr's.  My buddy runs a 300hp 7mgte supra motor in front of his stock 23 sp duals with 35's, and they are surviving so far.
bad luck
I've seen them hold up around 450 torq stock
boggerunner
here is my output shaft
