exo tube opinions
Started by tech201, May 10, 2008, 08:53:29 PM
tech201
going to start building an exo cage in the next couple months and not sure about tubing size. was thinking 1.5x120 dom but not sure if its too small strength wise and looks wise. any suggestions maybe some pics with 1.5 and maybe somthing bigger like 1.75
1.5 DOM should be ok.  if it were hrew i wouldn't go any less then 1.75.
Yoat Goat
I think you'll be fine with 1.5x.120 DOM.
T urning
O ver after
Y ears
O f
T rail
A buse
Redbeard1
IMHO the 1.5"  looks a little small I like the 1.75" look better. As far for strength  that all depends on the grade of tube you buy.
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
gotrocks
Quote from: Hyena on May 10, 2008, 10:00:11 PM
x2 DOM is much better but more expensive.  For a cage I only use DOM personally especially if your going 1.5x.120
1.75 HREW has held up pretty good in some of our trucks.  even to some heavy hits.  the 1.5 HREW doesn't seem to hold up very well though.  DOM is tougher, but for the cost it is up in the air.
tech201
ya i think the 1.75 would look better too but i have a 1.50 die so i dont want too buy the 1.75 die at around $300
