Author Topic: Bad Fuel Tank Sending Unit  (Read 4035 times)
myyota
  • Turtle Points: -1
  • Male Posts: 120
  • Member since Nov '06
« on: May 03, 2008, 08:20:53 PM »
I have an 86 4Runner with a 22RE and the gas gauge sending unit it bad, when it reads 1/2 a tank im out of gas. is the sending unit seperate from the fuel pump ?, how much is a new sending unit and were is a cheap place to buy one ?. would a sending unit from a 91 toyota pick up with a 22RE work in my 4Runner ?.
86 4Runner
Solid Axle Swap, 5'' Of Lift, 37x12.50-15 MTR Tires, 5 Speed Manual Swap, Inchworm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5''Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears and an ARB, Downey Header, Optima Battery, Trail Gear Sliders.
  • Turtle Points: 2872
  • Male Posts: 8,707
Re: Bad Fuel Tank Sending Unit
« Reply #1 on: May 03, 2008, 08:36:33 PM »
i thought it uses a float? is it possible the float arm is bent?
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #2 on: May 03, 2008, 08:48:22 PM »
It uses a float that is connected to the sending unit, I believe. The sending unit sends the voltage signal indicated by the float.
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
« Reply #3 on: May 03, 2008, 08:53:48 PM »
Yes the pump is removable from the rest of the sender. OEM baby. it just :twocents:
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #4 on: May 03, 2008, 08:59:28 PM »
So if I pull the pump, will the sender come up with it? Then I just remove the sender from the pump? Or does the sender go in a different hole on the tank? I need to replace the sender on the 85, thats why I am asking.
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #5 on: May 03, 2008, 09:02:11 PM »
I've got an 85 tank in my 83. diff holes. so was the 83 tank too.
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #6 on: May 03, 2008, 09:03:11 PM »
Ok, so I will assume the sender goes in the smaller hole. :thumbs:
brainlessfool
  • Male Posts: 4,207
    • Buy me a cigar
« Reply #7 on: May 03, 2008, 09:09:27 PM »
Are you REALY asking me "what goes in the small hole"?  :laugh: yes.
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #8 on: May 03, 2008, 09:11:21 PM »
:yupyup:
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
« Reply #9 on: May 03, 2008, 10:01:02 PM »
The fuel pump & fuel sending units are in 2 different locations on the tank. The access plate under the right rear seat will only get you to the fuel pump. You have to drop the tank to get to the sending unit  :twocents:
87 4Runner redo
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #10 on: May 03, 2008, 10:04:14 PM »
Or remove the bed?
Tallchevy
  • Male Posts: 3,562
« Reply #11 on: May 03, 2008, 10:18:37 PM »
Or remove the bed?
He has a 4Runner.
On a truck I would loosen the rear bolts & remove the front bolt & tilt it up.
87 4Runner redo
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #12 on: May 03, 2008, 10:19:45 PM »
:doh: I was thinking my truck. :hammerhead:
Tallchevy
  • Male Posts: 3,562
« Reply #13 on: May 03, 2008, 10:20:34 PM »
87 4Runner redo
EASYRYDERDANGER
  • Turtle Points: 1856
  • Male Posts: 215
  • Member since Jul '06
« Reply #14 on: May 05, 2008, 07:57:31 PM »
Its easy. Buy the part.  Drop the fuel tank out the bottom, i think there is 6 12mm bolts.  I dont remember if the sender is attached(detachable however) to the fuel pump like most are(chevys).  Or you can just make it easy and buy a new fuel pump and sender, but like the dude said previously in the post by stock parts from toyota.
Last post Feb 13, 2005, 12:16:55 AM
by laoseth
Last post Nov 25, 2009, 07:51:49 PM
by 1985SR5
Last post Oct 19, 2011, 02:55:13 PM
by Zs Confederate Toy
Last post Aug 12, 2021, 02:09:31 PM
by toy4todd
Last post Jan 24, 2023, 08:00:04 PM
by toyomr285
