0 Members and 6 Guests are viewing this topic.
i was wondering if you have to take out the inner axels to remove the third member.
when you only pull the axle out part way, do you need to support them? i was wondering if the axle weight might hard on the seals. any tricks?? or just do it and don't worry.
what Minisimp does is leave the wheels on, this is how i do it so you raise the truck enough to just barley clear the tires, remove the brakelines and nuts and lift the tire a little and pull it out, this adds some safety to removing the third memberthe tire should keep the axle off the seal, but if your replacing it, just leave the axles in till you get the 3rd out then pull the axles and replace the seal
ya me too after seeing that.... although I am yet to ever have a truck fall off the jackstands and hope I never do
Started by J.D.Zuki Engine
Started by trt2 Parts Wanted
Started by medtro Parts Wanted
Started by 4RnrRick New Member Check-In!
Started by Hyena « 1 2 3 » New Member Check-In!
