what ignition
Started by donkeykong, July 08, 2004, 12:45:43 AM
donkeykong
what type of ignitions setup do most run? Are you all just running stock, or upgrading to a MSD setup?  I want to get my little 22r running at as good as I can, and I know with out a good spark the fuel cant burn...So what are the options
Skinny_Pedal
jacobs has a nice and simple setup for yotas. i saw it at www.truckperformance.com
Im an OG
Jacobs makes a very good setup indeed.  I know of people running msd setups and they are all happy with them, but if & when I upgrade it'll be jacobs.
Skinny_Pedal
ok i made a mistake. truckperformance carries msd. performace accesories carried that jacobs unit
Im an OG
Performance wants way too much as a rule for yota stuff.  Your better off buying from summit.
Skinny_Pedal
i would like the jacobs unit. in the end what does it do?
Im an OG
Marlin
The factory setup I feel is the most reliable.
I have seen all other units fail sooner or later.
One of my customers installed a MSD setup and it seemed to make a noticeable change. It lasted about one year and than left him stranded. He mounted it on the drivers fenderwell and I felt it overheated. After sending it in for warrenty, it is now mounted on the passerners side near the wiper motor and it has worked perfect ever since.
Marlin
Skinny_Pedal
well thats nice to know. how does the box overheat. i didnt know that stuff like that could overheat?
Im an OG
Prismo
It would have been mounted near the exhaust the first time
Skinny_Pedal
so it was the header heat that did it. the unit it self didn't malfunction?
Im an OG
Marlin
I do not care for the Jacobs units.
I have seen many of them take a dump wheeling in the Sierra heat in California.
Three years ago on the Sierra Trek, I saw 3 trucks that lost their Jacobs units. Have not spoke kindly about them since then.
I am still running the same factory coil and igniter on my 1980 crawler truck.
I have upgraded to Nology ignition wires with the ground straps and run single ground Boush platimun plugs.
3 years ago, Big Mike got me a Nology super coil for Fathers day--2 years ago it let me down in the rain in Arizona at the Glitter Glutch Run. Thank goodness I had my factory coil with me.
Marlin
Marlin
With all the fancy ciructs and boasting about how good they are, I just feel that it must be the engine compartment heat that makes them go south.
I have noticed that most units have a large aluminun heatsink to help get rid of the heat.
Now if only they came with a 10 foot wiring harness.
Marlin
Skinny_Pedal
well toyota is known for its reliebilty. so if it aint broke dont fix it, is what it all comes down to?
Im an OG
donkeykong
Thanks for the input everyone :biggthumpup:.  After what marlin said about them taking a dump I may just stick to stock...or I can just carry my stock coil with me on the trail
