fj60 front end
Started by puunui, March 28, 2008, 11:34:15 PM
puunui
does a 85 drive shaft fit on the fj60. flange on the pinion. thanks
Going out on a limb I don't think so... I think its just a bit different....  wouldn't be a big deal to dril la new pattern into one though.
Hammerhead
The bolt pattern should be different but the centering lug is the same throughout the years and models.  Like WT said it is cake to redrill to the new pattern.
FJ60s use the same splines at the slip joint so you can just pull the mini slip-joint apart and replace with the FJ60 part from the donor FJ.
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
