only got code 7 TPS.....
OK i cleaned out all of the vacuum ports of the intake manifold and triple checked the lines and they all look good. I took a piece of .5 in tubing and listened for leaks or a hissing sound and nothing. I switched the EGR with another one and same deal. I will try to do as 93tonkatoy says and block off the EGR system and see what happens do you have a picture that shows the nut you are talking about just to make sure? I screwed the idle set screw all the way in and its still runs so = vacuum leak. what about the TPS code this thing is throwing?
Started by rEdnECkwHeE1eR Chit Chat Camp
Started by guywithuglyyota General 4WD Discussion
Started by Tice Toyota Pickup/4Runner Tech 1979-95
Started by Cheesemaker Chit Chat Camp
Started by Total Distorsion Toyota Pickup/4Runner Tech 1979-95
