hi khagerty-- Yes...you can adapt your V6 DSL to fit in the 4 cylinder 3rd by using "adapter carrier bearings" part number 32010X by Timken. I think http://www.greatlakeoffroad.com/ sells them.ZUK
2001 4Runner 3.4LHere is the Toyota part number for the wires: 19037-62010Here is the Toyota part number for the spark plugs: 90919-01192
koyo inner and outer bearings LM102949, JLM104948 race LM102910, JLM104910i would only use the koyos myself
part number for the VSV (2wd and 4wd ADD) on the wifes 1999 4runner with the V6, it is the blue one on the drivers side fender well.85440-35010 084800-1631
Not a Toyota part number but If you cant find Toyota injector harness pig tails to replace the ones that are so easely broked on 22re injectors here is a general motors part number with better weather seal boot that will work.I used these to replace all 5 of the injector plugs on my truck while I was doing the engine swap they will also work for about half of the other sensors on the engiine. GM part # 12085491 Discription: Connector
Started by Weldo Toyota Pickup/4Runner Tech 1979-95
Started by Dr.Maxwe001 Toyota Pickup/4Runner Tech 1979-95
Started by Dr.Maxwe001 Toyota Land Cruiser Tech
Started by FjordWarrden Transfer Case/Drive Line
Started by dweinberg01 Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
