Here are the specs from the person that built the engine (Blatant on PBB)
-- 22RE with fresh rebuild using factory new Toyota turbo pistons, bored .030, 8.0:1 compression, Calico coated bearings, adjustable timing chain with steel guides, new turbo head, new factory turbo valves, bronze valve guides, supercharger built by KF industries for a fuel-injected 22re. The company has changed names to Fageol superchargers. 5 pounds of boost. New cat and easily passes AZ emissions. EGR is removed but included.
From this truck...
http://www.pirate4x4.com/forum/showthread.php?t=387772The supercharger is gone.
![Sad :(](https://board.marlincrawler.com/Smileys/marlin/sad.gif)
The truck has been green stickered, trail only since it has been in Ca, so the mileage is still very low, I would estimate under 10k. Since it is green stickered (and running on a fuel cell) I don't know how it will do on smog. I'll have to double check if the EGR is still missing and if I have one to include.
I do not think it is a factory turbo block, so it would probably need to be drilled and tapped for the oil line if used with a factory turbo setup. It would work GREAT with this supercharger setup. :grinpimp:
http://www.pirate4x4.com/forum/showthread.php?t=662972It's still in the truck and running (though the truck isn't really driveable). Come and hear it run. Can make a package deal on as much as you need as far as wiring or whatever. There is a header on it that I won't be using either.
Located in Riverside, SoCal. NO SHIPPING
$750 obo
