Everything is located in 24060 Blacksburg, Va …. I will ship everything here ON YOUR DIME … ACTUAL COST. Discounts for 3 items or more ……
I WILL NOT SHIP THE AXLES!!!!!!!!!! I WILL NOT PART THE AXLES!!!! TIRES AND WHEELS STAY WITH THE AXLES UNLESS I HAVE PAYMENT FOR BOTH OF THEM!!!!!
-----unknown vendor toy 8" 1.5mm rubber diff gasket - reusable - $30 for the pair SOLD
-----brand new locking hub hardware kit - $40 ----- SOLD
-----knuckles - $65 ----- SOLD
----- 4 x new steering studs with e-12 head ... $5 SOLD
-----new-used hub hardware kit - $25 -----
12 used toyota hub cone washers
12 new class 8 lock washers
12 new class 8 nuts
-----8 x used factory toyota hub studs - $5 (threads are of unknown condition, some are good, some are bad)
-----steering arm hardware kit - all new - $30 ($40 from marlin + shipping)
8 x stud nut
8 x stud split washer
8 x cone washer ... + 2 cone washers for a total of 10 ... added a few for droppage on the trail!!!
-----steering arm hardware kit - used cone washers - $15
8 x stud nut
8 x split washer
8 x used cone washer (factory toyota ... some are mangles around the split where they were removed with a screwdriver)
-----14 factory steering studs, used - $5
----- spindles – These have surface rust from being out in the garage for the last year and a half. .---- $65 for the spindles
----- IFS calipers – worked when pulled – good paint on them (high temp caliper paint)----- $50 for the set
----- yota SA wheel hubs: new hub studs, they were wirewheeled, primer etched, and painted with high temp paint... needs bearings, no rotors. $50
----- pair of axles out of a mid 70s chebby .... 44 front and 12b rear, 354 ratio i believe
both axles are rollers with wheels and 35 MTs ... tires are bald, only good for spares, two leak slowly ... tires are free pretty much, you have been warned about the tires.
Front chebby 44 with the often sought after flat top knuckles, complete from wheel to wheel with push pull drag link still attached. junk yard condition, spins freely. $400
rear 12b, complete from drum to drum, still has most if not all brackets. $200
both of these came out of a running truck ...
$550 for the set.
NO SHIPPING, NO PARTING ... dont ask.
located in blacksburg, va 24060
