Transmission Whine
Started by 4by20, June 25, 2004, 09:08:51 AM
4by20
MARLIN, HELP!,
I just bought a 95 Runner V6 5spd. Love the truck..wish I bought one sooner!
Only problem is it whines in every gear except 4th. Sounds like a firetruck siren in first, and 2nd....real quiet whine in 3d and 5th.
I read your diagniosis on a W-56 trans with the same problem. You said basicly once the bearings go, the teeth start to wear and you can replace the bearings all you want, the whine comes back unless you completely rebuild the thing. Is it the same story with the R-150?
yotaboy79
im not marlin but im pritty shure i know his answer although i could be wrong but i think his answer would be
yup same story
SWAMPER
 :psss: Dont listen to YOtaboy he is on  :moon:  hehehe jk I also think its going to be the same thingy :thumbs:
4by20
Thanks...I agree with you guys...looks like there's a rebuilt trans in my future  :smack:
Ok, I just caught this one in the newbie section - sorry 4by20 - Marlin and I both have missed your posts!!
I will let Marlin read it and see what his advise is - hopefully tonight!
Skinny_Pedal
well for fun u should change the tranny fluid. 81toy4x had a whiny noise in his tranny and changed the fluid and there was no more noise. 81toy4x also new a guy with a runner like yours but auto and changed the fluid and all better. its worth a shot, cause it cost like 10 bucks tops to change the fluid
Im an OG
SWAMPER
Hey my tranny is hard shiffting so im getting the fluid changed and adding Lucas Oil additive I will do that on fri or saturday.  :_oops:
Lucas is very good stuff!  I use everything that they have in my vehicles Ive had nothing bad to say at all about their products.
SWAMPER
Yeah I have heard nothing but good stuff of Lucas also...I think I once heard that there was something better than Lucas (dont know if it was AMSOIL) but I cant remember the name. :)
83yota
AMSOIL is very good stuff i run it in everything. my buddys dad is a dris.
Brian83
good man 83!! I agree amsoil is the way to go for everything
Common sense just isn't that common anymore
Marlin
#11
One of the problems with the R150F V6 trans-t/case assmble is that there is a dead air space between the back of the trans and the front of the chain driven t/case. After hundreds of thousands of miles, the rear output seal gets hard and lets trans oil leak into this area between the boxes. From the factory, there is a gasket between the trans and t/case so it is possible to run the truck with very low trans oil without any visual leaks.
Running the trans low on oil will result in the input gear, and front countershaft gear, [also called constant run gears], to become overheated and begin to transfer metal. Once this happens, the input and countershaft are scrap and must be replaced.
Because of the large oversize bearings found in the R transmission series, bearing failure has not been a common problem like in all other L, G, and W transmissions.
Check the trans oil level and if it smells burned.
Changing the oil is always a great idea and only costs a few bucks although it will not correct your noise.
Because the countrshaft is not used in 4th gear, there will not be any noise, and since 4th is straight thur the trans, there is no load on the bearings so it still could be bad gears or bearings.
Time to pull the trans, tear it apart, and do it right.
Marlin
SWAMPER
Sounds likf 4by20 will be having some fun  :yupyup:
4by20
Thanks all!
I checked the trans fluid, it's full and smells like a machine shop..not sure if it's burned, but I'll change the fluid anyway. Hopefully it'll keep me goin untill I can get another trans.
Marlin: Thanks so much, I appreciate your indepth description. Looks like I may be purchasing one of your rebuilt transmissions in the near future.
Oh yeah..tons-o-fun Lilswamper  ;)
Use 80-90W GL5 oil if you go Mineral, or, Amsoil / Redline 75-90W if you go synthetic.
Synthetic oils should only be used in items that are already broken in (such as your transmisison).
If you use mineral, make sure its GL5 quality!
yotaboy79
is there a differense between broken in and just plain broken????? :headscratch: :hammer: :dunno:
Quote from: yotaboy79 on June 29, 2004, 02:30:38 PM
Good eye!  You know we gotta keep these college kids in check.
yotaboy79
lol i havent even made it to college yet and i prolly wont if i do it will just be for the partys :beer: :yupyup:
SWAMPER
Quote from: yotaboy79 on June 29, 2004, 03:17:46 PM
Yotaboy the only reason that I know you cant be my long lost twin brother is cause your yunger than me but we practicly think the same way  :hammer:....hey maybe you could be my son? Ive always been really fisty  :laugh: :laugh:
yotaboy79
i doubt it cuz (no offense i have no mexican in me) mostly irish (explains my drinking)
4by20
Quote from: BigMike on June 29, 2004, 02:05:54 PM
I just ordered a rebuilt R150F from Marlin, so I'll definately go with the 80-90W GL5. I appreciate the advice!
SWAMPER
Quote from: yotaboy79 on June 29, 2004, 09:54:05 PM
Well you dont have to have mexican in you....   :psss: Someone did though  :joke:
Hey Mexicans drink a bunch too...I think I lose count after #15  :boozer:
Skinny_Pedal
wow didnt even wait till the tranny went to buy a nice rebuilt one. :thumbs:
Im an OG
SWAMPER
Yeah them rich kids are like that  :hahaha:
4by20
yyeah..I wish I was rich...
You should hear this thing..sounds like a fire truck siren in 1st & second & I drive 65 miles a day through Boston. Not to mention my release or pilot bearing sounds like a newly wed couple on a spring bed. Who ever owned this truck before me, really neglected to service it. If you had this set up, you'd replace it too.  :driving:
SWAMPER
Oh defenetly...but I would have proly waited till the danr tranny fell off and I would have to push it like 5 miles :yupyup:
4by20
man...you must be so strong!  :bowdown:
SWAMPER
Oh and did I mention It would proly be Uphill too since I live in the "hillcountry"  :yupyup: ....strong...I say TOO strong! :joke:
yotaboy79
i wated tell my input shaft floped around and split the case :_oops: oh and to top it of i was doing about 75 and the tranny damnear locked up
