help my build up
Started by 83yota, June 24, 2004, 07:11:46 AM
83yota
ok up date time. my trans is going out in a hurry. i need to get my engine in. due to the fact that my foot went through my floor board i need to get a new cab because my body mounts are where is rusted. well i was going to ask all of you: i found a mint cab today for $50 should i get it. thanks for your input. :beerchug:
Brandon
Quote from: 83yota on July 12, 2004, 06:28:03 PM
where? I might want it if you don't!
Brandon Miller
RCRC, Sacramento, CA
www.RiverCityRockCrawlers.com
83yota
i found it in my friends wrecking yard (gold mine for toy parts.) :thumbs:
If you dont buy that other cab you must be way stoned!  Its actually pretty damned easy to change it over just takes time.  It would be worth it in the end Ill guarantee it!
83yota
i think i will due to the fact he said he will through in the doors also, they are kinda hamered but i just want to make half doors anyways. do you think i should under coat the cab while its off? :_order: :flamer:
Brandon
Quote from: 83yota on July 13, 2004, 03:38:41 AM
I hate undercoating.. If anything sandblast it and put a good coat of something on on there but undercoating leads to flaking and then you get rust from within..
Brandon Miller
83yota
what do you recomend? i dont want to use paint. i was thinking bed liner what you think?
Brandon
Quote from: 83yota on July 13, 2004, 05:48:36 PM
why?
I actually have the spray on paintable undercoating on mine, the stuff I hate is the stuff you get done and it looks like bunch of snot. As long as it is an even coat it's all good..
Brandon Miller
83yota
so do you think herculiner is a no go?
84runner
I would think some kind of bedliner would be good, just make sure you prep the area reall good that is the best prevent measures you can take
83yota
cool i think i am getting my cab and dorrs tomarrow. thanks :thumbs:
83yota
ok heres an update. engine is coming along great. but i need to find out if ne one knows if painless builds a kit to put the 5.0 in my truck due to the fact my harness is wrecked. :beerchug:
Id be willing to bet that they do make a harness for that engine.  They seem to make everything else.
83yota
how could i contact them? i dont have a dealer close due to the fact that i live in BFE. witch happens to also be the flatest place on earth :headshake:
Call Summit 1800 230 3030 if they dont have a part # for the harness you need they will give you the # to get ahold of painless directly.
83yota
wow WT is the greatest. he is the one with all the answers. thank you WT
