Clearancing the wheel wells
Started by rockhound, February 16, 2008, 08:14:45 PM
rockhound
I've seen this done but wasn't real keen on attempting it. With 35's and the axle moved forward 1 1/2 " the tires would never rub. When I went to 37's, I started having trouble with the tires grabbing the bottom of the fender and rubbing at the wheel well.
Today I tore into it and got the drivers side done.
How you 'sposed to know what your limitations are, till you exceed them.
www.RunandPlayMotorsports.com
rockhound
rockhound
It turns out I was hanging on to this old door for a reason.
It just happened to have the right curve for the patch panel.
lilbuddy
RIP Kyota.... you are the man
GET IT!!!
86bobbedtoy
I predict this in my near future.
nice job!
KDXSR5
So you didn't weld it in there? If you didn't, then maybe I can do it when the time comes! I have no good welding skills.
Inittowinit
#7
"Lunatic friends, I know you're out there"
http://www.youtube.com/watch?v=3PGNCeVuYBw
Quote from: Inittowinit on February 17, 2008, 11:56:48 AM
..............................Soooooooo, is that piece held in w/ glue?(What kind?)..............And your not able to kick it out/in?
I would be worried about a log coming up in there and bustin through.....ALTHOUGH...I have seen people do something similar with plexiglass so u can see the log coming in...dunno
rockhound
Quote from: LILBUDDY on February 17, 2008, 10:47:37 AM
Looks good Al
:thumbs:
Thanks Chris.
For the rest of the interested parties..
Sorry the project wasn't documented better. Pics were a last minute idea. After the fact.
The panel is welded in. The caulk is just to seal it from dust and water entering the passenger compartment.
I still need to do the passenger side. Maybe I'll show the process start to finish.  :biggthumpup:
Quote from: rockhound on February 17, 2008, 02:24:59 PM
Thanks Chris.
cool...we was wondering about that! Looks nice....You made it look easy
RTA
Good job Al.  Don't slice up those tires!   :thumbs:
So. Cal. ROCK BRAWLERS
DieselD
should have cut more for when you go bigger.
Volcom
I am going to be doing the same exact job to fit some 40" Iroks.  I was hoping not to have to cut but there's no way around it.  Thanks for the pictures.
Rockyot - What did you use to cut your openings?  Was it hard to cut that close to the body mount?  Any more pictures?  Was the piece you welded back in flat or did it have a curve in it?
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
rockhound
Quote from: RTA on February 19, 2008, 05:41:42 AM
Ya, gotta keep 'em in good shape so I can shred 'em at the Hammers  :gap:
Quote from: rockyot on February 19, 2008, 11:50:59 AM
I don't plan going bigger any time soon. I do plan to increase clearance with some 6" springs and better snubbies.
rockhound
rockhound
smoothed it out with a grinding wheel after getting the rough shape with the nose saw.
rockhound
Hopefully got enough out for the 37's. If not at least they won't catch on the seam anymore and have a smooth surface to rub against.
rockhound
rockhound
moved the brain, caulked it in and painted it.
I need to head over to my Costco retaining wall ramp and see how I did.   :biggthumpup:
alwayzbroken
I added plexiglass windows when I did mine. It turned out really well for super steep crawling when you can't see anything. You can actually look straight ahead through the small windows like a windshield on both sides to see what you are doing when the front end of the truck is high up on trail terrain.
rockhound
Quote from: alwayzbroken on February 19, 2008, 06:59:21 PM
DirtToyBoy said something earlier about plexiglass. I like that idea. How did you attach it? How thick? Curved?
alwayzbroken
#22
Quote from: rockhound on February 19, 2008, 07:03:17 PM
I drilled the necessary holes in the plexiglass and the floor then put a bead of silicone around the plexiglass before laying it down and bolting it in for the last time. It is flat. It is not hard to shape the sheet metal into a flat surface. I cut out the sheetmetal first, patched the hole then cut out the window I wanted from the fully patched floor. I put silicone over all the tack welds and seams. Probably not necessary but I wanted everything sealed good so it wouldn't rust through right away.
alwayzbroken
Quote from: alwayzbroken on February 20, 2008, 10:10:25 AM
The view
oh come on...you  could of at least put a pic of a naked chick or something behind it :shake:
rockhound
Alwaysbroken. Cool idea. Nicely done.  :thumbs:
i dont know if i could get used to the plexi in the floor... i do think it looks cool though.... what about it scratching? would lexan have been better?
alwayzbroken
Quote from: DirToyBoy on February 20, 2008, 10:27:17 AM
Do you really want me to?
alwayzbroken
Quote from: jimbo74 on February 20, 2008, 08:08:09 PM
It isn't scratched after two years. I'm sure lexan would have been better. I don't foresee the plexiglass being an issue though. Its small size helps it retain a lot of rigidity.
DieselD
Quote from: Volcom on February 19, 2008, 12:09:34 PM
I used a combo of cutoff wheels and plasma cutter. the foor near the body mount is double think but the plas made easy work of it. the key is just to cut a little at a time until you get the desired size. i also tried to lien everything up so I would have less curves in the patch panal as possible. Im no body man!!
here are a couple more pics
the start of the patch
no finished pictures I guess?? Ill take some tonight
