XX-CAB (back to X-CAB)
Started by RTA, February 14, 2008, 06:14:37 AM
RTA
Well I thought that I only busted my bottom knuckle cap.  :shakehead:  Nope bent the top of my axle ball where the bearing seats.  :shake:
I got a new to me housing and started cleaning it up.  Did a little body work on my fender that got smashed.  :_order:
So. Cal. ROCK BRAWLERS
95SAS
nice damage.... good job  :clap: fender looks nice  :thumbs:
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
CrazyYota
That sucks! even the gusset bent! :yikes:
toywthbdydmge
 :beerchug: way to go Teag getr done  :yupyup:
4DEES
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
RTA
twistedtoy92
iNfErNaL
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
RTA
Still welding on all of the gussets and trusses.  Only welding small amounts at a time not to heat up to much.  Almost done with that and should be back in the truck this weekend.  :thumbs:
RTA
Got the axle done and back under the truck.  Still on the trailer but now I can drive it off.  :greengrin:
Welded up the drain plug and ground it down, knuckle ball gussets, diff. armor, and top truss.  Knuckles rebuilt and new to me bottom knuckle pins.  New tie rod ends and some new bushings.  New grease, gear oil, and paint.  :yesnod:
twistedtoy92
Thomas P
'14 Camry SE
SCX10 Honcho on roids!
BNRSHNTZL
Matty
looks great, but how do you check/fill that diff?
RTA
It's off the trailer and in the garage. :clap: Could be ready right now.  Just want to add, fix, and modify a few things.
RTA
Quote from: 85xtracab on April 09, 2008, 01:01:33 PM
Thanks.
The stock fill plug is still there.  I just drain it when I pull the third.
Wermz84
I like to Drive!
iNfErNaL
  :cool:
Wermz84
 :o  Wow Teag looking good!   :thumbs:
I like to Drive!
Duffil
thanks for the pics Peps...Teag that thing looks sick. Why you been holding out?
RTA
Thanks Peps!   ;)
Thanks guys.   8)
RTA
Quote from: Duffil on November 21, 2008, 07:28:49 PM
  Started a new job a couple of months ago.  Not as much time to do the things I want anymore. I have not had to work a 40 hour week in 10 years.  It sucks.  But at least I have a job.
  So, the truck has been waiting for me.  Always so many things I want to do to it. The first was to lighten up the load.
