1999 TOYOTA TACOMA XTRACAB 4x4 DANA 44 SOLID AXLES
Started by 4Runnerguy, February 11, 2008, 08:03:58 PM
4Runnerguy
3.4 engine with only 99k original miles, clear title with no accidents.  Nice shape throughout. Automatic, A/C, tilt, pioneer stereo.  Stock engine except for ca smog legal air intake and electric fans.  Using synthetic oil.   Upgraded to solid axles, front Ford high pinion Dana 44 with Chevy 6 lug outers, E-Z locker with Yukon 5.19 gears.  Rear is a Jeep J-10 Dana 44 with matching gears and Detroit locker.  New 37 MTR's on aluminum rims.  Warn 8274 winch with in cab control.  Runs good, I am using as a daily driver right now.  If this is what you are looking for, would definitely be worth the drive to El Centro, CA $9000, you can't build one like it for that price.  760-960-3283
AaronB
ripnrr
You never know how you look in someone else's eyes!
notyourmomslx450
was it wrecked or did the airbag deploy at some point?  the airbag part of the steering wheel looks like it's a different color than the rest of the interior.  can you post the VIN?
-Jason
"Daily Destroyer"-'94 xtra cab, solid axle, longs super set, 5.29s, detroits, dual ultimate, 37" MTRs, bobbed 12", Gulf Coast Crawl Shop bumpers, custom dents :eek:
"The Anchor"-'97 LX450, OME J-springs & L-shocks, spring spacers, wheel spacers, 35" Super Swamper SSRs, ARB, rack, it's just getting started
4Runnerguy
OK here is the deal, I am getting messages on what a good deal this is and what is wrong with it? So here is the deal with the truck, I want $9000 because that is what I have into it. The title is clear, no accidents and paint is stock, not covering anything up. The DS airbag is a little bit of a different color because when I got the truck it had one of those stupid Grant steering wheels, it had the stock steering wheel in the back seat and I got a grey airbag and painted it tan to match a little better, if you want a matching tan bag you can get one on ebay for about $100 and just replace it, the airbag system tests fine. Truck is ready to go and dependable as is except I would finish the highsteer, has a crossover steering right now, but has a stock tie rod in the stock location, looks too close to springs and should be raised anyways. You would need about $400 in parts, Tundra oil pan, DS Sky steering arm, and a new tie rod made, everything needed should be bolt on. This truck stock with this low mileage would sell for $8k, so for an extra $1000 you get a winch and solid axles with lockers, the only problem is you would have to drive down to so-cal to get it. Truck should have no problems driving back to wherever you want. It is smog legal as well as street legal.  The vin # is 4TAWN72N0XZ452884 and I have a clean carfax if needed.
4Runnerguy
Sold, somebody got a good deal, was definately worth his drive.
