86 and later rearends
Started by stehlydan, June 20, 2004, 08:47:53 PM
stehlydan
I have been reading that it is wise to swap to a 86 and later rearend if you have lots of flex.  This due to the tire hitting the frame.  I have a question about those reaends.  Do both 4 cyl and v6 third members fit in the housing?  I would definetly be going with the stronger v6 gears.
Skinny_Pedal
as far as i know the v6 3rd member will go right in there
Im an OG
BLUCRUZ
Quote from: stehlydan on June 20, 2004, 08:47:53 PM
Yes cause it's 3" wider than 79-85. Yes the v-6 & 4cyl thirds are interchangable in all 79 to 88 housings. Newer Tacoma e-locker thirds will fit too with some minor modifications to the housing. :beerchug:
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
Any standard 8" Toy diff will fit in there.
Skinny_Pedal
how much better is the v6 3rd. and is the fj80 an 8"
Im an OG
stehlydan
86 runner I was wondering the same thing myself.  I want to go with the 86 rearend in the back with a v6 third member and up front use a fj80 for the high pinion.
84runner
The v-6 has more ribs for strength in the 3rd member casting and that's about all I know  :dunno:
