FS: 1987 Toyota 4Runner $1300.00 Waukesha, WI
Started by twicks69, February 05, 2008, 04:18:31 PM
twicks69
Hey guys,
I am getting rid of my 1987 Toyota 4Runner SR5 4WD 2-door:
*****Has BRAND NEW Yokohama Geolander AT-S 31"x10.5"x15" Tires with less than 100 miles on them!  I just spent $800.00 for them!
***5-Speed Manual Transmission with Manual Transfer Case
***Tranny shifts excellent -- clutch is working just fine
*200,000+ on the vehicle (Mileage around 204K).
*Primer Black, Grey Cloth interior
*Detatchable cap; Gen 1 4-runner
*Power rear liftgate window with carpeted bed
****Heat works great
****22RE 2.4L 4-banger engine -- still running strong
****Has the altimeter/pitch control gauge cluster
*New Distributor Cap and Rotor, Spark Plugs, Plug Wires, Belts, 2 year old front struts, and a Newer Water Pump.
Ok, it runs and drives just fine, but it isn't perfect by any means -- I have used it for the last 2 years as a Jobsite vehicle and have had a great time driving it; I am only selling it because I purchased a newer vehicle for a permanent driver.
It NEEDS a steering idler arm at the least == that is the most worn out part of the steering, and makes it a little loose to drive -- it isn't broken, just worn out.  You can get these for around $25.00  or less on Ebay:
http://cgi.ebay.com/ebaymotors/86-Up-FACTORY-TOYOTA-4X4-TRUCK-4-RUNNER-IFS-IDLER-ARM_W0QQcmdZViewItemQQcategoryZ33587QQihZ021QQitemZ310016895149QQrdZ1QQsspagenameZWDVW
The rear passenger sliding glass window on the truck cap is shattered, but being held together by a mat of black duck tape -- It has been like that for 2 years without problems.  Here's an ebay auction for a replacement piece:  ~25.00-35.00
http://cgi.ebay.com/ebaymotors/84-89-4runner-sliding-glass-window-drivers-rear_W0QQcmdZViewItemQQcategoryZ33684QQihZ002QQitemZ120175889977QQrdZ1QQsspagenameZWDVW
It leaks from the rear main seal, transmission output shaft seal, and rear differential -- It is 20 years old...if you had 200K on your body, you would be leaking out of every orifice also.
The rear leaf springs are nearly inverted -- it is a very common thing on all 4Runners; 4500# with too small of a factory leafspring setup.  They are easily upgradable and there are many sites that sell upgrades.  Here's an auction for upgraded  replacement leaf springs:
http://cgi.ebay.com/ebaymotors/Superlift-4-Rear-Leaf-Spring-1979-89-4Runner-Pickup_W0QQcmdZViewItemQQcategoryZ33585QQihZ007QQitemZ170165249174QQrdZ1QQsspagenameZWDVW
The vehicle has no stereo or speakers; the way it has been for as long as I have owned it.
The passenger door was hit in the past and was replaced with a manual window version; the replacement door isn't perfect.  I am also INCLUDING a pair of extra doors with interior panels and windows with the sale.  The passenger door window manual window lever isn't on the track, so I have just sealed it.  I also have an extra pair of manual window levers included for the other doors.
The rear lift gate window switch isn't hooked up; I have been using an extra battery placed behind the drivers seat with wires going to the window itself to raise it up/down if necessary.  Again, a switch is in the vehicle; but not wired up properly--another thing from before my ownership.  Here's a replacement switch if necessary:
http://cgi.ebay.com/ebaymotors/84-91-4runner-rear-window-switch_W0QQcmdZViewItemQQcategoryZ50459QQihZ001QQitemZ110217734253QQrdZ1QQsspagenameZWDVW
Interior is fair -- the drivers seat has wear marks/rips along the outer bolster, but is still extremely comfortable and has adjustable lumbar/upper bolster supports.  The passenger and rear seats are just fine.  The back seats fold down to increase storage area of the truck bed also.
The sliding windows on the drivers side of the cap work just fine.
The AC worked; it just isn't hooked up; the belt has been removed.  The cruise control works just fine, along with the driver side power mirror.
Overall, it is a great working truck that can be used and abused without worries and is a genuine Toyota from the 80's.  It was made to beat the :pokinit: out of and have fun.  Fortunately for you, the 22RE just isn't powerful enough to get you into much trouble with the law unless you are offroading.  It does up to around 72-75mph MAX -- it is around 4500# with a 4-banger.  It is definitely a good vehicle if you have had speeding tickets in other vehicles; because you definitely won't get one in this unless you are speeding in a school zone.
It can be seen by appointment.  Please PM or e-mail me for details.
$1300.00.
I also have a turbo manifold with a 14B and a downpipe/IC piping if interested.
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5071&d=1202243057
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5072&d=1202243057
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5073&d=1202243068
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5074&d=1202243068
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5075&d=1202243076
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5076&d=1202243125
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5077&d=1202243125
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5078&d=1202243134
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5079&d=1202243134
http://www.brewcitymuscle.com/forum/attachment.php?attachmentid=5080&d=1202243149
Tim Zimmer
twicks69
ttt.
Looking to get this thing sold -- the sooner the better!
Tim Zimmer
